Should I buy?
03-23-2009, 10:29 PM
Should I buy?
Hi everyone, im a big fan of AE since around 1998 and was always dreaming of one , now i got a chance and i wanna know what you guys think of it.
It from JDMSkyline i saw the car in person and seems healthy, and it run like a charm, start in 1-2 ingition.
http://www.jdmskyline.com/JDM_cars/418/1...20No%20387
BTW im new to the forum and to AE, never driven one before this weekend.
03-24-2009, 12:53 AM
Should I buy?
Looks like a very clean import! Smile
I can't say for sure if it is rust free from pictures, but looking at the floorpan it does look clean. Check the fenders and the insides for rust to be sure. Also check on the right side under the door for rust because the sideskirt is missing... If there is rust near the holes which held the sideskirt it will most probably be the same at the other side. Wink
[Image: AEU86 AE86 - Should I buy?]
03-24-2009, 01:01 AM
Should I buy?
Thanks ya im going back there this weekend, il try to deal it under 7.2k
il give it another run and il do a compression test.
and thanks for noticing the Sideskirt havent seen it ^^.
03-24-2009, 11:53 AM
Should I buy?
Seriously, if I were you.
I will worry about the chasis more than anything else.
Worry about the motor last.
try and get the car up on a hoyst.
And see if there are anything bent or any bad rust spots.
03-25-2009, 02:25 AM
Should I buy?
Ya im definately putting it on a lift to see the frame, and ive chek the sub frame look clean but still, it expensive for a AE so looking for more response thanks everybody.
03-25-2009, 04:35 AM
Should I buy?
I would check the rear arches pretty well, the car has had the bottom half re-sprayed, might have had a bit of work done recently.
03-30-2009, 11:09 PM
Should I buy?
Still looking for some Reply it an expansive Bought so need maximum info.
Thanks.
04-26-2009, 03:52 PM
Should I buy?
UP need some opinion ! im probly buying my ride this week so review would be nice thanks alot.
  How far should I have to push my clutch in dinkers542 4 6,433 11-29-2014 11:18 PM
Last Post: dinkers542
  All I should know about suspension before any modification damusto 20 22,668 05-24-2013 09:28 PM
Last Post: damusto
  What's the LSD oil I should use? heshan 4 6,634 07-25-2011 08:13 PM
Last Post: heshan
  Where should this part be??? Dino86 2 3,592 09-22-2010 09:51 PM
Last Post: HybriD07
  what should i do? AEeighty-six 7 7,720 06-25-2009 11:12 PM
Last Post: NoHachi
