What's the LSD oil I should use?
07-21-2011, 07:50 PM
I'm not really particular about the brand.
I had a leak in my oil seal in one of my axle's and now i have to replace the oil so wondering what the oil should be. thanks, Heshan. Cheated on my いたずらな女の子 and now I can't get enough of her.. |
07-21-2011, 08:32 PM
Personally I use Castrol SAF-XJ or Redline 75W140
07-21-2011, 08:38 PM
I saw in one of the HachiRoku.net that they recommend 75w90..
Is that correct? Cheated on my いたずらな女の子 and now I can't get enough of her.. |
07-21-2011, 11:42 PM
Actually Toyota recommended SAE 90 API GL 5 and 80W90 for winter.
If you intend to use your 86 only on road, you can stay with 75W90, but don't forget to use LSD oil ! Personally, I use my 86 on road and on track for drifting. This last application "stress" a lot the mechanics, so I prefer to use oil with an higher grade (it also help to reduce a little bit the noise) |
07-25-2011, 08:13 PM
Thanks mate..
How far should I have to push my clutch in | dinkers542 | 4 | 6,873 |
11-29-2014 11:18 PM Last Post: dinkers542 |
trans oil, lsd oil change | Apolan | 9 | 18,467 |
Oil cooler -> low oil pressure | Jan Pedersen | 24 | 33,547 |
All I should know about suspension before any modification | damusto | 20 | 24,065 |
LSD Oil, Necessary? | phill 92 | 6 | 9,254 |
04-06-2012 05:17 PM Last Post: Sgonzalez |
