Silvertop Install, Clutch Flywheel problems, please help!!
08-04-2008, 02:37 AM
Should be fine then... no different from fitting a clutch kit to
your previous setup. For the car to move forward the clutch must be getting some sort of contact. Maybe the high rotational speed when disengaged, causes some small movement of the pressure plate ? Enough to just kiss the clutch plate ?? Does your clutch take up with the pedal close to the floor, or not until the pedal is almost at the top of its stroke ?? If it takes up as soon as the pedal leaves the floor, you most likely have a problem with your slave cylinder. Cheers... jondee86 |
Messages In This Thread |
Silvertop Install, Clutch Flywheel problems, please help!! - byd1380 - 08-03-2008, 08:09 PM
[] - jondee86 - 08-04-2008 02:37 AM
20v Silvertop - New Haltech ECU & Couple of questions | 20valver | 10 | 2,695 |
Big wheel problems | gh0st | 16 | 8,608 |
Starting problems 4-AGE kouki | Hanzo | 3 | 2,753 |
20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 13,835 |
TUV RHD AE86 Germany (help please) | 4dori | 9 | 7,184 |
07-17-2019 07:42 PM Last Post: Hachigo83 |
