Simple Question about Fuel Pump Mount
04-25-2008, 01:38 PM
I have an SR5 and am doing the GTS swap. So far things are going alright, but our fuel pump needs a GTS bracket.
Is the bracket native to the ae86 or can we use an AE92 GTS or a MR2 fuel pump mount?
If not, how much will the bracket run me (could not find online).
Thanks!
04-26-2008, 06:01 PM
bump?
04-27-2008, 12:07 PM
You need the AE86 bracket.
04-27-2008, 03:28 PM
Yes you do need it because the tanks are different as well.
East Coast Toyota
http://ectoyotas.com/forum/index.ph
Club4AG
http://www.club4ag.com/
04-28-2008, 02:22 AM
The only difference between an SR5 and a GTS tank is that the GTS tank has better baffling around the pickup. You can still happily use an SR5 tank, although you may suffer with a bit of fuel surge.
Brackets from other cars may well fit the bolt pattern, however obviously the length is the critical issue.
04-28-2008, 04:46 AM
Thanks all for the replies. It is much appreciated. Turns out I will just be getting an entire GTS tank since someone local had it.
Thanks for your insight!
04-28-2008, 08:43 AM
Make sure you have a look inside with a torch to make sure it isn't rusted
05-01-2008, 01:11 AM
Tanks are different so good luck or buy a new race tank.
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
05-01-2008, 09:35 AM
No, tanks are identical except for internal baffling differences.
GTS pump bracket bolts into SR5 tank.
  Engine mount replacement - tips/tricks ? ondafly 4 1,673 02-24-2026 12:34 PM
Last Post: ondafly
  20v BT - which oil pump? Mylesmck 4 5,894 06-21-2022 04:51 PM
Last Post: pack
  Gearbox mount and transmission mount gh0st 9 7,510 05-08-2022 03:28 PM
Last Post: totta Crolla
  Fuel pump issue DJexor 11 11,344 04-29-2022 05:45 AM
  fuel line hose from the pump Wikizz 4 8,466 10-16-2017 07:11 PM
Last Post: jdm86gtz
