Small question about wheels
07-18-2013, 11:46 PM
I know this is a AE86 forum, but i have a question about wheels:
I found some cool used rims with the sizes: 14x6J-114.3. Now, what if 'my car' (Toyota MR2 AW11 NA) has 4x100 bolt pattern instead of 4x114.3 which is stated above. Does these rims fit 'my car'? I have no experience with enginering cars, but what do you need to do so they can fit, or is it impossible?? The AE86 has 4x114 so that's no problem. Oh, and i read something about adapters. Don't know what it is. -Vortrex Quote:“The One With The Stronger Heart, Always Wins The Battle!!!”Let's Go Out of Here..... Together..... “1988 Toyota MR2 AW11, My Go-Kart AE86!” |
07-19-2013, 08:00 AM
They won't fit.
They can be made to fit, but for 14x6 you would be mad to do so. There are TONS of nice 4x100s for sale in NL. A wheel to steer the front of the car A pedal to steer the rear |
07-19-2013, 09:58 AM
These are adapters...
http://prowheeladapters.com/4x100-to-4x4...apter.html You just need to do some measuring to make sure that your wheels will fit without the tyres rubbing if you use adapters (also known as bolt-on wheel spacers). Check your local legislation to make sure they are legal (if you care) before buying. Some countries require the spacers to be hub-centric and stipulate the maximum thickness allowed. You also need to check if there are recesses in the back of your wheels between the bolt holes. If you use 25mm thick spacers and your existing wheel studs are 30mm long, the extra has to have somewhere to go !! Cheers... jondee86 |
07-19-2013, 12:29 PM
Okay, thanks for your answers!
*EDIT: actually, i was searching for wheels, for the future. But i couldn't find lot of used watanabe's. Do you know some good places to find those? Quote:“The One With The Stronger Heart, Always Wins The Battle!!!”Let's Go Out of Here..... Together..... “1988 Toyota MR2 AW11, My Go-Kart AE86!” |
07-19-2013, 01:02 PM
Vortrex Wrote:Okay, thanks for your answers! Auction Yahoo http://auctions.yahoo.co.jp/ Then use a shopping service like Celga or something. Tho for wheels i think that shipping is gonna be pretty expensive. Ebay UK http://ebay.co.uk Driftworks (Not Watanabe but alot cheaper and they're new and wider) http://www.driftworks.com/rota-rbr-in-gu...-et10.html http://www.driftworks.com/rota-rkr-15-wh...lours.html |
07-19-2013, 01:43 PM
Check VW forum. 4x100 is a common size in europe.
Early tvis red top from e9 gti small or bigport? | Ryo | 3 | 7,585 |
Small Port Swap | Alex170984 | 1 | 4,234 |
11-21-2016 01:46 PM Last Post: Alex170984 |
Small Port 10.3 Pistons | Alex170984 | 1 | 4,398 |
10-25-2016 09:18 PM Last Post: oldeskewltoy |
Question about AE86 Wheels | CHACAMAN | 5 | 11,149 |
09-10-2014 02:17 AM Last Post: zenki |
small port engine | totta Crolla | 4 | 5,886 |
07-03-2010 10:05 PM Last Post: totta Crolla |
