Smallport Head swap
06-08-2016, 09:54 AM
Smallport Head swap
Hi,
Is the bigport fuel rail not interchangeable with the smallport head?
cheers
06-08-2016, 10:06 AM
Smallport Head swap
No. The injector spacing is different.
Cheers... jondee86
06-08-2016, 11:16 AM
Smallport Head swap
Got a spare rail?
06-08-2016, 12:35 PM
Smallport Head swap
Is the distributor the same?
06-08-2016, 12:42 PM
Smallport Head swap
No not the same
06-08-2016, 01:16 PM
Smallport Head swap
Can I use the bigport dizzy though?
06-08-2016, 01:47 PM
Smallport Head swap
Yes you should be able to use the bigport dizzy.
Daily Beater: Civic EG5
Work in progress Car: AE86
06-08-2016, 03:49 PM (This post was last modified: 06-08-2016 03:50 PM by Bean.)
Smallport Head swap
Just to confirm, fuel rail is not interchangeable the dizzy is.
06-08-2016, 07:31 PM
Smallport Head swap
Are you sure,im pretty sure something was different?
they fitted but something inside was not the same if i remember correct
06-09-2016, 12:11 PM
Smallport Head swap
The AFM dizzy is the same (except the connectors, but it can be changed easily) The MAP smallport distributor is a unique thing for me, so its not compatible with the olders!
  Smallport coil totta Crolla 2 1,922 08-12-2022 11:03 AM
Last Post: totta Crolla
  Smallport inlet manifold totta Crolla 6 3,717 01-17-2022 05:14 PM
  4A-GTE 7-rib smallport nyberrg 5 6,591 05-24-2017 09:24 PM
Last Post: krullibull
  Smallport Fuel Rail Alex170984 2 4,743 11-19-2016 08:44 PM
Last Post: Alex170984
  4A-GE: Bigport with smallport fuel injection nyberrg 7 11,945 06-13-2015 05:00 PM
Last Post: nyberrg
