Some aftermarket parts FS
03-06-2007, 10:53 AM
Hi there,
Thanks for letting me post in here as I hope to provide you good Euro folks some good aftermarket or std replacement parts for your beloved 86. FYI, Im from Malaysia and trade mostly Toyota and Nissan parts as well as Mazda and occasional Mitsubishi as well. Parts I have are mainly from Japan or made locally in Malaysia. Prices will usually be as just parts/products alone (unless stated) Would appreciate if someone can guide me on the taxes scheme for imported parts into the EU so I can further assist in getting exact quotes on parts prices. So look out for my postings ! PM or email [email protected] |
03-06-2007, 11:18 AM
ke86 Wrote:as well as Mazda Thats my man! danielvanderwoude Wrote:looks like the nmwisima joke saved you in the endhttp://www.jdmbits.com |
03-06-2007, 11:25 AM
1. NEW VIOLENCE OIL CATCH TANK *MADE IN JAPAN*
SELLING FOR ONLY : EU 55 ! Product Information: Oil Catch Tank catches the oil and moisture in the blow-by gas that causes carbon and sludge build-up in the intake system and the engine. It keeps the engine clean even under hard driving conditions. VIOLENCE Oil Catch Tank is also an excellent engine dress up item, enhancing the look of a highly performance racing car. Latest Oil Catch Tank design, compact and powerful. Cast, machined, and polished aluminium tank Clear braided hose with EARL"S Econ-o-fit hose clamps. Sight tube for monitoring the oil level. Improves car performance and well maintenance to engine. Mounts vertically or horizontally Universal Fitting, Suitable to All types of Car Comes complete with hose Easy installation with manual included 2. CUSCO Oil Catch Tank 9mm Fitting *Made in Japan* SELLING FOR ONLY : EU75! PRODUCT DESCRIPTION: - One new GENUINE Cusco Oil Catch Tank with 9mm hose for most: Naturally Aspirated (N/A) cars. Turbo cars. The dimension of the catch tank is approximately 15cm (height) x 8cm (diameter) in size. Cusco oil catch tank is used to reduced the oil vapours from going into the air intake charge. The oil vapours contaminate the air intake charge by mixing with the air and fuel that are used to create combustion in the engine. As a result of this contamination, it reduce burn efficiency, increase detonation risk, and power factor in both naturally aspirated and turbo cars. Beside reducing the oil vapours going into the intake charge. The oil catch tank enable a turbo cars to increase approximately additional 3psi of boost without the risk of detonation. It is easy to install, however bracket may need to be modified to suit the application. 3. D1-Spec Breather Tank *Made in Japan* SELLING FOR ONLY : EU 60! PRODUCT DEscriptION: - Genuinely Made in Japan Dimension: Length: 140mm X Diameter: 70mm 13mm Outlet & 13 mm Inlet Reservoir Tank that is made from 6061 T6 lightweight aircraft grade billet aluminum Beautifully Tig welded aluminium pressure tank Comes complete with brackets and all necessary fitting kits Removes air from your engine and radiator, prevents air locks and leaves room for expansion High Quality and Long Lasting 4. New F1-Z Racing Sport Oil Catch Tank (Made in Japan) SELLING FOR ONLY : EU60 ! Product Information: - F1-Z Oil Catch Tank catches the oil and moisture in the blow-by gas that causes carbon and sludge build-up in the intake system and the engine. It keeps the engine clean even under hard driving conditions. F1-Z Oil Catch Tank is also an excellent engine dress up item, enhancing the look of a highly performance racing car. Latest Oil Catch Tank design, and compact Cast, machined, and polished aluminium tank. Clear braided hose with EARL"S Econ-o-fit hose clamps. Sight tube for monitoring the oil level. Improves car performance and well maintenance to engine. Mounts vertically or horizontally. Universal Fitting, Suitable to All types of Car. Comes compete with hose and mounting brackets. Easy installation with manual included. Shipping cost estimate is about EU 65 for each of these catch tanks but can vary depending on country. Shipping will be via Fedex Air Mail. Payments can be made by TT into my bank account. I understand there is a certain handling fee when doing a TT via banks so I suggest that you order more items at one shipment so we can both save on shipping cost and TT fees. Pls contact me either by PM or email shall you require more details. PM or email [email protected] |
03-06-2007, 11:53 AM
You should really create a Paypal account
03-06-2007, 12:46 PM
Man, why are you guys always so far away! Ah well, cant win them all. Wellcome!
03-07-2007, 02:17 AM
nmwisima Wrote:You should really create a Paypal account Hi nmwisima, Can you pls guide me or point to a link on how I can get one done? thanks PM or email [email protected] |
03-07-2007, 02:19 AM
Some aftermarket parts FS | |||
03-07-2007, 06:13 AM
More items for sale :
1. 555cc injectors - 4pc for sale SOLD fit CA18DET, SR20DET GTiR etc Top feed and low impedence EU 150 2. Blitz LM. Adaptor not included. (used) SOLD EU 65 3. Blitz SUS 6". (used) SOLD EU 75 another view PM or email [email protected] |
03-07-2007, 08:46 AM
4. BLITZ FATT DCII SOLD
EU 90 The BLITZ DTT (Dual Turbo Timer) DCll is a one of a kind item. This is the only turbo timer in the world that incorporates a turbo timer with a boost gauge. The digital boost display can read up to 2.5hkpa (36.75psi) and also includes a digital boost peak hold. This unit also features the two-piece design that allows the user to virtually mount the turbo timer anywhere in the vehicle. PM or email [email protected] |
03-07-2007, 11:06 AM
Selamat datang, keep them coming You can ask joe to join here too, lots of friends here interested in Trueno front conversions
Some parts that i sell | Max_Misawa | 78 | 72,777 |
06-03-2007 05:46 PM Last Post: alimonos |
