Spark Plugs-Map Vacuum Pressure-S-AFCII Mapping Q's
02-26-2005, 03:18 AM
The standart manifold vacc. has to be atleast 590 (factory info) with a idle at 850 rpm, but mine is giving around 540 at a idle of 950-1000 rpm. I think this is because i have a open freeflow airfilter. I think yours is lower caused by your ITB´s.
High an low throttle: Mine is set for 0-100%, you have to use the Throttle angle sensor to do so. NOT the closed throttle signal. When you map the engine, you MUST do it on a dyno. I havent experimentet with mine S-AFC, unless giving it suffecient fuel to die when reving the engine ( just to find oyt, that the shit really works), so i really cant help you out with that. Youtube Myspace and I´ll Google your Yahoo |
Messages In This Thread |
Spark Plugs-Map Vacuum Pressure-S-AFCII Mapping Q's - PazzaAE86 - 02-26-2005, 01:22 AM
[] - Knudsen - 02-26-2005 03:18 AM
AFM to Map Conversion | ps13michi | 3 | 3,109 |
Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP | mister86 | 12 | 10,903 |
Build your own adjustable fuel pressure regulator ;) | oldeskewltoy | 8 | 20,885 |
Weak spark, doesn’t start. | AlexFourTwenty | 4 | 15,129 |
extracted freedom ecu 16v ignition map | ditn | 7 | 8,793 |
