Spark Plugs : which ones to use 4age ?
07-23-2007, 12:06 PM
Dear all,
I replaced the spark plugs on my 4AGE small port. I used the same ones which were in in the engine when I bought it :
NGK BCPR6ES. Unfortunately I do not know the gap... Does anybody know this. Cannot find this data on the NGK site. Are thes NGK ok for this engine ?
I know platinum type spark plug is better, but which one to use ?
Info in the net is not so clear about this.
Jos Evers
Netherlands.
07-23-2007, 01:19 PM
The manual specifies one of the following:
Copper:
NGK BCPR6EY11
or
DENSO Q20R-U11
electrode gap is 1.1 mm.
Platinum:
NGK BCPR5EP11
or
DENSO PQ16R
i use copper denso and they've worked fine. Though theese are for the stock engine. Maybe smallport uses different type. ??
07-23-2007, 01:32 PM
The plug you are using (NGK BCPR6ES) is correct for your 16V
smallport engine. Gap is 0.8mm. NGK are good plugs and I would
stay with them... I use them myself Smile
Platinum last longer, but there is no real evidence that they offer
any performance advantage on a healthy ignition system. Better to
save your money and just replace the standard plugs every 10,000km.
Cheers... jondee86
07-23-2007, 02:24 PM
and what plugs do you guys use on a large port?
thinking about these ones: NGK BKR6EIX
Good or no good?
Regards!
53.6 Tsukuba: http://www.youtube.com/watch?v=Kd-AnG3LYUg
try this one: http://www.youtube.com/watch?v=t1IiUAtoNBk
07-23-2007, 05:57 PM
Thanks a lot for your help guys !
I will stick to the ones I use now, Since I change them every year together with the oil & filter etc. ( 10.000km .
Thank you for your explanation.
jos
07-24-2007, 08:46 AM
Can someone clear the situation?
AFAIK the BKR6EIX is for the smallport engine and the BCPR6EY for the bigport, or...?
1987 Toyota Corolla GT coupe - for holidays oversteer
2005 Toyota Corolla - for daily understeer
07-24-2007, 09:40 AM
The manual specifies parts for the stock motor - stock motor is large port. Therefore BCPR6EY are for largeport. If i remember correctly NGK catalog specifies the same. Don't know about smallport though.
07-24-2007, 09:58 AM
All the bigport (TVIS) engines use 1.1mm gap plugs. In the
NGK range they would be :
BCPR5EIX-11 Iridium
BCPR5EP-11 Double Platinum
BCPR5EY-11 Copper
5 is the stock heat range for everyday round town driving. For racing
you might want to go to a slightly colder 6 heat range e.g. BCPR6EY-11.
I used these for years (6's) in a bigport for all types of running, and
never had a problem.
The smallport would use 0.8mm gap NGK plugs :
BKR6EIX Iridium
BKR6EP-8 Double Platinum
BKR6E Copper
Using BKR6E in my smallport and they work fine Smile NGK and Denso are
the factory recommended brands, and I wouldn't use anything else.
Cheers... jondee86
07-24-2007, 11:51 AM
Thanks johndee
07-25-2007, 11:56 PM
thanks!
  20v BT - which oil pump? Mylesmck 4 2,885 06-21-2022 04:51 PM
Last Post: pack
  Weak spark, doesn’t start. AlexFourTwenty 4 15,552 12-12-2017 03:35 AM
Last Post: AlexFourTwenty
  Rim width. Which is best.... Dino86 5 6,897 01-07-2017 03:09 PM
Last Post: Dino86
  which connector is this ditn 7 7,831 07-27-2015 11:24 AM
Last Post: pack
  Haslbeck front spoiler, which foglights? wouter86 2 5,147 02-15-2015 11:14 AM
Last Post: ditn
