Spark Plugs : which ones to use 4age ?
07-23-2007, 12:06 PM
Dear all,
I replaced the spark plugs on my 4AGE small port. I used the same ones which were in in the engine when I bought it : NGK BCPR6ES. Unfortunately I do not know the gap... Does anybody know this. Cannot find this data on the NGK site. Are thes NGK ok for this engine ? I know platinum type spark plug is better, but which one to use ? Info in the net is not so clear about this. Jos Evers Netherlands. |
07-23-2007, 01:19 PM
The manual specifies one of the following:
Copper: NGK BCPR6EY11 or DENSO Q20R-U11 electrode gap is 1.1 mm. Platinum: NGK BCPR5EP11 or DENSO PQ16R electrode gap is 1.1 mm. i use copper denso and they've worked fine. Though theese are for the stock engine. Maybe smallport uses different type. ?? |
07-23-2007, 01:32 PM
The plug you are using (NGK BCPR6ES) is correct for your 16V
smallport engine. Gap is 0.8mm. NGK are good plugs and I would stay with them... I use them myself Platinum last longer, but there is no real evidence that they offer any performance advantage on a healthy ignition system. Better to save your money and just replace the standard plugs every 10,000km. Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
07-23-2007, 02:24 PM
and what plugs do you guys use on a large port?
thinking about these ones: NGK BKR6EIX Good or no good? Regards! 53.6 Tsukuba: http://www.youtube.com/watch?v=Kd-AnG3LYUg try this one: http://www.youtube.com/watch?v=t1IiUAtoNBk |
07-23-2007, 05:57 PM
Thanks a lot for your help guys !
I will stick to the ones I use now, Since I change them every year together with the oil & filter etc. ( 10.000km . Thank you for your explanation. jos |
07-24-2007, 08:46 AM
Can someone clear the situation?
AFAIK the BKR6EIX is for the smallport engine and the BCPR6EY for the bigport, or...? 1987 Toyota Corolla GT coupe - for holidays oversteer 2005 Toyota Corolla - for daily understeer |
07-24-2007, 09:40 AM
The manual specifies parts for the stock motor - stock motor is large port. Therefore BCPR6EY are for largeport. If i remember correctly NGK catalog specifies the same. Don't know about smallport though.
07-24-2007, 09:58 AM
All the bigport (TVIS) engines use 1.1mm gap plugs. In the
NGK range they would be : BCPR5EIX-11 Iridium BCPR5EP-11 Double Platinum BCPR5EY-11 Copper 5 is the stock heat range for everyday round town driving. For racing you might want to go to a slightly colder 6 heat range e.g. BCPR6EY-11. I used these for years (6's) in a bigport for all types of running, and never had a problem. The smallport would use 0.8mm gap NGK plugs : BKR6EIX Iridium BKR6EP-8 Double Platinum BKR6E Copper Using BKR6E in my smallport and they work fine NGK and Denso are the factory recommended brands, and I wouldn't use anything else. Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
07-24-2007, 11:51 AM
Thanks johndee
07-25-2007, 11:56 PM
thanks!
20v BT - which oil pump? | Mylesmck | 4 | 2,585 |
Weak spark, doesn’t start. | AlexFourTwenty | 4 | 14,936 |
Rim width. Which is best.... | Dino86 | 5 | 6,682 |
which connector is this | ditn | 7 | 7,509 |
07-27-2015 11:24 AM Last Post: pack |
Haslbeck front spoiler, which foglights? | wouter86 | 2 | 4,979 |
02-15-2015 11:14 AM Last Post: ditn |
