Speedo sometimes quiets working
10-10-2004, 08:45 PM
Hey Guys,
I'm guessing this is a loose cable but its dark outside right now and tomorow is the MOT retry so I need to figure out what this is. (although if I dont its still up to the previous owners responsibility to fix itSmile)
My speedy sometimes doesn't work. Often a light tap on the instrument cluster fixes it, tonight however, as dead as can be.
I'm guessing a loose wire or something like that. Any suggestions where to look? Do I need to take my instrument cluster out for it?
10-10-2004, 11:05 PM
I often hear guys complaining about the worm gear in the gearbox, which drives the speedometer, it's made of plastic and when it fails..no more speedo. If on the other hand mean your instrument panel lighting fails sometimes, mine does to...it's a common problem. Just keep tapping the light switch until it comes back to life. The problem can be solved by a little creative resoldering of the circuitboard behind the switch. There was a little write-up on club4ag a while back in the electronics section. I havent done mine yet.
10-11-2004, 12:06 AM
Ivan lights work fine..
The speedo just stops working for awhile, and then works again. I just went to pick up some snacks, 10 minutes I hit the gas, suddenly the speedo works again. Hopefully it will work again in the morningSmile
10-11-2004, 08:45 AM
Remove dash get your tacho and speedo meter out and check the cables :-)
10-12-2004, 11:10 PM
Robo,
Rats, I was afraid of that, awell work for the weekendSmile
10-12-2004, 11:11 PM
mux213 Wrote:Robo,
What about your MOT? I heard you got it, so no probs with the speedo at all?
[Image: AEU86 AE86 - Speedo sometimes quiets working]
10-12-2004, 11:12 PM
Yupz,
It was working the whole day again, it only shuts down from time to timeSmile
11-12-2004, 01:11 AM
I think I figured out what is wrong with my oil pressure sensor. Both connector and the part the wire is attached to are corroded. Need to clean them up somehow...
  Brake lights not working takumi_mt 2 791 03-07-2024 03:42 PM
Last Post: takumi_mt
  working out compression ratios kazi 2 3,684 07-16-2019 08:22 PM
  Dash lights not working. kazi 5 7,525 05-09-2017 12:31 PM
  Headlights - only high beam working Jezza_hr 3 7,517 01-10-2015 11:59 AM
Last Post: jondee86
  Carina TA62 / TA60 heater blower stopped working Bushido 9 11,539 11-14-2014 12:57 AM
Last Post: Bushido
