Spindle dimensions, backing plate bolt pattern
03-13-2014, 12:35 AM
Rascal21 Wrote:I.e if the shocks are modified OEM toyota items, just get the corresponding OEM shocks and slam inserts+coilover sleeves on those instead? Yes, once you know what you got, thats what you should do! 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
03-13-2014, 12:37 AM
I measured the bolts from outter to outter at 73,5mm and each bolt at Ø15,75mm so thats 57,75mm bolt spacing I think?
1x AE86 84` Zenki Coupè Levin 4A-GE 20v 1x AE86 83' Zenki Coupe Levin 4A-GE 16v 1x TA60 82' Sedan 2T 8V 1x TA40 78` MK1 Zenk/Pre-Facelift Wagon 4A-GE 16v |
03-13-2014, 01:02 AM
Rascal21 Wrote:I.e if the shocks are modified OEM toyota items, just get the corresponding OEM shocks and slam inserts+coilover sleeves on those instead? or buy aftermarket replacement coilovers for them and bolt them on if i'm at my barn this weekend, i can measure a set of shocks from a EP82 Starlet. "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
03-13-2014, 01:14 AM
Nice! Any measurements that line up here would be extremely helpful for my plan to install the front coilovers this car deserves.
I just got back from an email chat with T3, and according to a drawing that they sent me (Which I dare not post here), which showed bolt spacing/pcd of RA40, TA22 and TE72 hub carriers, my measurements are the most consistent with TE72 hub carriers: And remember my measurements are according to a well-used caliper: My hub carriers have 64,75mm square PCD for caliper brackets. TE72 hub carriers have 64mm square PCD for caliper brackets. My spindle diameter are 17,5mm outter, 30mm center, 40,9mm inner. TE72 spindle dimensions are 17,5mm outter, 29mm center and 41mm inner. This is too good to be true? I finally know what hub-carrier I have? 1x AE86 84` Zenki Coupè Levin 4A-GE 20v 1x AE86 83' Zenki Coupe Levin 4A-GE 16v 1x TA60 82' Sedan 2T 8V 1x TA40 78` MK1 Zenk/Pre-Facelift Wagon 4A-GE 16v |
03-13-2014, 01:22 AM
TE71/72 could be it indeed. It's a quite common car around the world, and compatible with AE86 stuff, so easy to source parts for. And if you're making a custom big brake setup, the base doesn't really matter, as long as the basic stuff fits
03-13-2014, 02:48 AM
Yeah!
Just had a chat with my mechanic, he confirmed they are indeed TE71/2 spindles, so only need a set of TE71 struts and adjustable inserts (sleeves already ordered) The hunt for adjustable TRD inserts begins.. Thanks a lot for your help and input everybody! 1x AE86 84` Zenki Coupè Levin 4A-GE 20v 1x AE86 83' Zenki Coupe Levin 4A-GE 16v 1x TA60 82' Sedan 2T 8V 1x TA40 78` MK1 Zenk/Pre-Facelift Wagon 4A-GE 16v |
03-13-2014, 11:36 AM
Adventure not yet over..
I made a mistake in listing the measuring, my wheel hub has a Ø29mm (inner diameter) inner wheel bearing, which will not fit the Ø30mm (outer diameter) TE71/2 spindle.. Everything else lines up though.. 1x AE86 84` Zenki Coupè Levin 4A-GE 20v 1x AE86 83' Zenki Coupe Levin 4A-GE 16v 1x TA60 82' Sedan 2T 8V 1x TA40 78` MK1 Zenk/Pre-Facelift Wagon 4A-GE 16v |
03-13-2014, 11:45 AM
On second thought, jamiemirror adviced this might be because of milled spindle due to previous damage, so I`ll get to measuring the LH spindle tommorow and find out for sure!
Mocal oil cooler & sandwitch plate ordered | Gtsi-R | 48 | 54,665 |
Cam Cap Bolt Snapped!! | Alex170984 | 1 | 3,664 |
06-08-2018 01:17 PM Last Post: Ivan141 |
crank 6 bolt flywheel | DJexor | 5 | 7,950 |
12-05-2016 08:21 AM Last Post: d3nso |
brake booster difference zenki(2 bolt)/kouki 4 bolt v | ditn | 1 | 4,288 |
03-22-2016 09:43 PM Last Post: ditn |
4A-GE 20V ITB bolt patterns | kjb | 7 | 11,770 |
02-27-2016 01:23 PM Last Post: kjb |
