Springs and shocks
02-28-2006, 10:47 PM
Springs and shocks
Could someone give me some advise for spring/shocks that lowed my hachi about 2 or 3 cm. I am looking for springs that confortable for daily drive hachi (this mean no need those springs for race/drift)
Price would be about 100 - 250 euro for 4 springs. Brand/type/part number would be very please. And for shocks price does not matter. But please resonable one and confortable. This not mean that I would buy now, I need to save for it and hope before summer I can buy those. Thanks p/s: Please excuse error gramma/typo for my english. |
02-28-2006, 10:59 PM
Springs and shocks
Oldskull neem een setje APEX verlagingsveren gaat je 30cm mee naar beneden.
Corolla RWD AE86 85 / 87 170-2010 30 mm Dat is het bestel nummer Netherlands RS Trade B.V. Markerkant 1058 1316 AJ Almere Holland Tel.: 036-5400313 Fax: 036-5295515 ff bellen 170-2010 geloof iets van 130 euro is een goed setje hoef je ook geen schokbrekers te vervangen als je dat gaat doen en je wilt iets sportiefs dan kan je bv tokico blue nemen is goed koop en aardig. Wil je voor altijd klaar zijn moet je gele koni's kopen. maar das duur dus begin maar es met veren. Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
02-28-2006, 11:16 PM
Springs and shocks
Hey Lennert,
Bedankt voor snel advies. Maar je bedoel zeker 30cm echt of 30mm ? |
02-28-2006, 11:25 PM
Springs and shocks
Hi, couldnt understand almost anything but APEX are cheap and not too harsh, those lower your car 3cm or 30mm and cost me 140€ here in Portugal. (just to clear the 30cm
![]() ![]() 85 Red Toyota Corolla GT - project "vouàfalencia" |
02-28-2006, 11:29 PM
Springs and shocks
Hi joaotcgt,
Sorry about dutch. Yes I already found out it is 30mm. |
03-01-2006, 03:38 AM
Springs and shocks
Best order some tokico blues to go with those springs..they are pretty cheap and a tremendous improvement. Running more springrate on the stock units will wear them out more quickly and cuase them to spend much time on either the bumpstops or the droopstop..bad. Also driving an underdampened car can be dangerous with possibly uncontrolled bodymovements during fast transitions..
So just order the entire set for between 200 and 300 euro...it will be worth it though, makes a very nice and streetable setup. A wheel to steer the front of the car A pedal to steer the rear |
03-01-2006, 09:18 AM
Springs and shocks
Buy your self coilovers. Don’t waist your time and money with progressive one. Stock shocks length is to long for any kind of decent set of springs, especially if you want to lower your car. You can keep it as a winter set up. But for summer time go for coilovers.
Fun is not the straight line! |
03-01-2006, 10:23 AM
Springs and shocks
max,
Going coilovers, especially short stroke is alot of work. Definately a must if you want to do serious lowering or have interest in racing/drifting, but if I understood oldskool correctly when I talked to him, his interest is in getting a replacement for his aging suspention that feels a bit more sporty. Lowering the car a bit is just for the improved looks. With just a 30mm drop new quality shocks with a nice apex set will do more then fine for the type of use intended. When I bought my car it had the APEX springs and KONIs set to the lowest setting. I was very pleased with the way my car handled on the road. It wasn't until I started doing some serious track driving that I figured the car was in much need to be improved. But for normal road driving it is more then enough. APEX with Tokico blue sounds like the best buy to me if you just want a slightly lowered better then stock daily driver. It won't brake the bank (its atleast 4x cheaper then a good coilover/shortstroke conversion) and give you a comfortable sporty ride. I wouldn't go for KONIs unless you like spending money. KONIs (or other adjustable shocks) are a must when you want to do track driving but then I would always go short stroke and get the KONIs adjustable on car. Thats my end goal in a few years for my suspention but its total overkill for oldskool. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
03-01-2006, 12:23 PM
Springs and shocks
Mux213,
Do you know any type (manufacturer) of springs, stiffer than stock but with original ride height? I just want them little stiffer then stock, for approximately 30%, but with normal raid height, not to mess up with suspension geometry. I couldn’t find them on internet. Fun is not the straight line! |
03-01-2006, 02:45 PM
Springs and shocks
Thanks guys for suggestions
![]() I already make my mind. I would go for apex and tokico blue for my car. but i think my back shock are koni yellow, because I saw yellow color when the car on bridge. Only i cannot confirm because I dont check it either its koni or not. Stock shocks for hachi in yellow color? ![]() ![]() Anyway thanks again for help ![]() |
HKS valve springs | totta Crolla | 3 | 2,316 |
rear bilstein B6 shocks 2 types what to choose? | Ryo | 5 | 3,468 |
KONI Sports shocks for the AE86... | jondee86 | 11 | 20,928 |
Springs from other vehicles?? | FanIsHere | 16 | 14,952 |
05-17-2016 09:12 AM Last Post: FanIsHere |
Question about KONI shocks for an AE92 | Apsogos | 1 | 4,153 |
09-13-2013 07:40 AM Last Post: Apsogos |
