Standalone for AE86 4age to AE82 4age
09-02-2008, 09:59 PM
I have some questions.
Can i use a standalone kit for AE86 on my AE82 ECU? Have i change something? ll it Work?
**COROLLA EE80 - 4AGE 124HP**
[Image: AEU86 AE86 - Standalone for AE86 4age to AE82 4age]
09-03-2008, 05:35 AM
Yes you can use a standalone unit from the AE86 to be used on the AE82. But the pins are different on the ECU, which means you have to get connectors.
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
09-03-2008, 03:56 PM
What do you mean "the pins are differents"? My ecu has 10-18-14 pins. Exactly, my ecu is from celica-corona coupe-carina 4age 85-87. Here is a pic
but ihave an ecu from AE82 European edition like that
Can i use a map from AE86 to my car?
Thanks a lot mate
im waiting your answer.
09-05-2008, 09:10 AM
Have a look at the plugs of the AE82 ECU, it should be the same 10-18-14 configuration. The only possible difference will be in the pin functions. By that I mean that pin 1-10 in your AE86 ECU might have a different function to pin 1-10 in the AE82 ECU. Appart from finding the wiring diagrams for each one, you can take the covers off and have a look at the circuit boards. There should be a designation for each pin. If these all match, then plug and play. If not, then find your wiring diagrams and determine what each pin does.
09-05-2008, 10:11 AM
Thanks a lot mate but i dont have an ecu of AE86. maybe i can check it with wiring diagrams of ae86'w ecu and ae82'w ecu.
09-30-2008, 11:25 PM
Which brand do you think that i can use? standalone or piggyback? My project includes cam 272 10,3 lift, pistons 82mm
10-01-2008, 03:51 AM
You've got me a bit turned around here. So, you've got an AE86 wiring loom in there at the moment and you are a) changing engines, or b) changing computers?
It sounds like you're changing computers, as engine is just plug it up and go. So if you're looking for a standalone ECU then it doesn't matter. Just find one that you're comfortable with, considerations will be:
1)Price
2)Functions
3)Access to a tuner you trust
Just about all brands should be able to provide a linking cable to match your current loom to the computer. I would suggest a standalone over a piggyback.
  ITB convert need standalone ECU izanagi 2 6,885 04-07-2016 11:24 PM
Last Post: izanagi
  AE82 suspension compatablilty megabob 6 7,912 10-24-2013 06:34 PM
Last Post: Rob_GTZ
  20V VVT on standalone ECU fax0815 5 10,395 08-09-2013 09:27 AM
Last Post: rene
  Which standalone ECU for a Blacktop??? Aram 9 13,686 08-11-2010 07:47 PM
  AE86 16v standalone - any suggestions? woper 20 22,798 05-19-2007 12:23 AM
Last Post: woper
User(s) browsing this thread:
