Stock timing map?
05-24-2009, 01:44 PM
Stock timing map?
Does enyone now how its going stock timing map for Gts and how much it's moving with RPM?
Example:
16 at 900 RPM
??? at 2000 RPM
??? at 3000 RPM
??? at 4000 RPM
http://www.driftclub.rs
05-25-2009, 01:42 PM
Stock timing map?
There is a reasonable amount of information here...
http://www.ae86.hu/movies/Jeremy_Ross_Li...R2_ECU.pdf
Cheers... jondee86
05-25-2009, 03:01 PM
Stock timing map?
Yes but, how do we know BTDC values? they are in 0-255 scale
05-25-2009, 06:26 PM
Stock timing map?
further down on the document there is a map with BTDC
and i have one somewhere im my hard drive too
[Image: AEU86 AE86 - Stock timing map?]
there u go
05-25-2009, 11:21 PM
Stock timing map?
I was looking for 2D map, very hard to guess from 3d map. But it's a start
05-26-2009, 08:47 AM
Stock timing map?
check the link from jondee86 it's all in there
05-26-2009, 10:20 PM
Stock timing map?
Good info from jondee86 , thanks, but I still can figure out how I can make the best map. I have Megajolt ignition controler with Edis4 and it's working fine and I make some maps, but I want to make the best Map I can.
Here is one of my map and if someone have sugestion I will be glad to hear
05-26-2009, 11:14 PM
Stock timing map?
try using the table on the bottom of page 12 in Jon's pdf-file
although I hope you have someone close who is experienced to help you with this as making an ignition table from almost scratch is difficult to say the least and could go bang if you make a too big of a mistake
Addition: have a look here http://www.autosportlabs.org/viewforum.php?f=15
might be of help
05-26-2009, 11:16 PM
Stock timing map?
the only way to make the best timing map is os the dynamometer Smile
05-27-2009, 12:21 AM
Stock timing map?
I now that is the best do that on dyno but in my country is preaty expensive, and I will do one ore two meassurment when I be close to end for shure.
I now for Autosportlabs forum and I am on it (nick Vladimir), so I read every post there and it's helpfull with some maps,but not so perfect becouse nowone there have setup like me and it's only one 4AGE,Dr.Occa's.
About this table on the bottom of page 12, I dont understand quite what is cilinder filing(MAP sensor),think that is in my case load of engine in Kpa,am I right? And does I can somehow transform that unit from table in BTDC degress?
  Digital speedometer on stock dashboard FanIsHere 0 1,570 11-09-2022 01:36 PM
Last Post: FanIsHere
  AFM to Map Conversion ps13michi 3 3,527 01-06-2022 10:34 AM
Last Post: ps13michi
  82mm Stock compression Pistons apardal 4 3,039 11-24-2021 04:26 PM
Last Post: apardal
  Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP mister86 12 11,706 02-10-2020 06:39 PM
Last Post: Power_uP
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 13,959 07-18-2019 03:52 PM
