Streering problem!
01-14-2008, 05:50 PM
Streering problem!
I am having a little problem with my steering. When i steer to the left or right i can feel that the wheel gets a little hard. Could this be the steering links or barrings?
Anyone that can give me some tips about what i could be? This started after the first snow fall!
Thx
01-14-2008, 08:58 PM
Streering problem!
Have you checked the tyre pressures ?
01-14-2008, 10:01 PM
Streering problem!
Usually it is the universal joint from the rack to the steering column you can can remove it without taking the rack or column off, if you find a tight spot in the joint thats you problem.
01-24-2008, 08:55 PM
Streering problem!
road rally Wrote:Usually it is the universal joint from the rack to the steering column you can can remove it without taking the rack or column off, if you find a tight spot in the joint thats you problem.
I have been chasing a steering problem all around my front suspension for ages, after reading the above I checked the joint and found it to be stiff, changed it and now it's totally sorted, mr road rally Respect!
thanks !!
  4agZe problem solved - 99% IC problem Okami 41 40,882 07-12-2012 04:49 PM
Last Post: Okami
  AC problem? Idle problem? KD2229 3 5,454 08-19-2009 02:08 AM
Last Post: KD2229
