Supertech Valve are they better than stock
10-26-2009, 07:40 PM
Supertech Valve are they better than stock? What you can say about this company? thanks
10-26-2009, 09:54 PM
I only got them because they make OS valves. As for durability, they're using a hardening treatment which I don't think is applied to OEM valves. Should be a good buy if you're looking for stronger valves.
10-27-2009, 04:58 AM
becareful about that, harder springs mean more wear for your camshaft
10-27-2009, 11:21 PM
I thought we were talking about valves, NOT valve springs
10-31-2009, 01:11 AM
Need i something more to use them? i have HKS springs and hks camsharts other items is stock
10-31-2009, 12:36 PM
You'll be fine with what you have. Get the oversized valves. Your head will have better air flow.
11-02-2009, 03:35 AM
My memory is a bit hazy, but check out 3sge or 7mge valves. There was a post on Toymods, by Billzilla, ages ago about oversized valves from one of these engines. Fraction of the price for std Toyota goodness.
Given the price Toyota often charges though, it may be six of one, half dozen of the other ( or in this case 16). |
4AGE Valve Buckets Scored | Steller Engineering | 2 | 947 |
20 Valve Blacktop smoking after engine flush - why? | RolanTHUNDER | 2 | 1,464 |
Digital speedometer on stock dashboard | FanIsHere | 0 | 1,497 |
HKS valve springs | totta Crolla | 3 | 2,271 |
82mm Stock compression Pistons | apardal | 4 | 2,913 |
