Suspension question
03-09-2013, 08:36 PM
Suspension question
Currently on my car I have a set of Megan's racing coilovers. My question is would it be possible to replace there shocks with a set of tokico hts? I'm also planning on getting some swift springs.
Thanks! 1985 Corolla Gt-s Coupe ![]() |
03-10-2013, 05:54 AM
Suspension question
Why do you wanna change the megan coilovers?
03-10-2013, 07:58 AM
Suspension question
I'm just planning out what i want to do with my suspension for the future.
03-10-2013, 11:07 AM
Suspension question
Short story, Megan shocks are not hollow struts containing cartridges and will not take hts.
Sounds a lot like you wan't to mix things up just for the sake of it. A wheel to steer the front of the car A pedal to steer the rear |
03-10-2013, 02:20 PM
Suspension question
So you coilovers are perfectly fine? If so do not change them for the sake of changing stuff.
03-10-2013, 02:43 PM
Suspension question
if your megan coilovers losing performance, get the dampers refurbished, thats all. in theory, the megan large diameter pistons should work far better than the tokicos.
03-10-2013, 07:56 PM
Suspension question
Depends on the valving.. most Taiwan specials use very limited valving code types (one size fits all). There are shops in the uk and us now that will revalve them nowadays. Interesting option imho..
03-12-2013, 03:49 AM
Suspension question
I'm not going to do so at the moment. Just when i felt it was time to upgrade the suspension i want to go with the hts. If i could get them to fit with my megan's racing coilovers then great if not i would find a way to get them to fit onto my corolla. I think i have to get coilover sleeves?
03-12-2013, 08:30 AM
Suspension question
You need something like the T3 struts. Stock struts, shortened and converted to coilovers.
Front suspension question | leon205gti | 7 | 8,064 |
07-07-2013 05:32 AM Last Post: leon205gti |
oil catch can/ suspension question | fax0815 | 12 | 18,057 |
04-23-2011 01:31 AM Last Post: jondee86 |
