Suspension questions...Need quick response...
07-19-2009, 06:00 AM
I am starting an ae86 project with an empty shell. It has no suspension or anything else in the front, just the body. I need to know what parts are compatible between the corolla and the celica/supra.
07-19-2009, 02:30 PM
With the Celica Supra? I presume you mean the A6 Celica Supra... Not much I guess!
![]() Think stuff like pedalbox, brakebooster, wipermotor, etc. would fit, but they are not the same. Suspension is different, but probably the front strut will fit: AA63 struts do fit the AE86 but could give you positive camber... Engine could be fitted since someone already managed to shoehorn a 7MGTE into an AE86, but it takes heavy modifications to do so... Rear setup it totally different (IRS vs live axle) so if you want to reuse that you need some big modification to make that fit as well... 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
07-19-2009, 02:38 PM
well I am doing a ka24de swap... Ive been doing research on swapping the s13 suspension into the corolla any ideas?
07-19-2009, 03:59 PM
http://forums.club4ag.com/zerothread?id=33878&page=1
Here's some info on Ka24de swap and doktor on this forum has done a ke70 + ka24deT swap into his rolla. I think Zax project topic is worth looking into, as he's doing the s13 swap. Good luck ![]() Philip |
20v Silvertop - New Haltech ECU & Couple of questions | 20valver | 10 | 5,053 |
Windscreen stoopid(?) questions.... | Mylesmck | 7 | 2,562 |
04-30-2024 09:46 PM Last Post: Mylesmck |
Brake Bias Questions | mad.matt | 10 | 13,512 |
01-03-2019 04:54 AM Last Post: mad.matt |
4age hitting gas too quick means engine stalls - what is the issue? | Ryo | 20 | 33,896 |
06-27-2018 11:15 PM Last Post: Ryo |
Quaife quick rack | totta Crolla | 19 | 23,765 |
03-03-2018 03:32 PM Last Post: Deuce Cam |
