Suspensions and stearing setups
01-02-2007, 02:22 PM
dxaqta Wrote:for grip driving i run: Yes, I think the same... I will chage it to 6/5 F/R or 5/4 F/R... what feel you have whit this setup? ___________ Zax I have a problem with camber... I can´t reduce it, because I use it.... My tyres looks like slicks in the exterior ![]() Few time ago I had -1,5º camber and when i change it to 2º I feel less understeer and more grip, Is possible? but i dont want put more camber because I lose brake power in front tires. I know you have a lot of experience.... I think I can´t put less camber... what front setup do you think is good with this camber? ____________ Mux, yes of course, Toyo CF have the flank (i dont know if is the correct word) very soft and this don´t help to stop the understeer Regards and thanks! ![]() ![]() |
01-02-2007, 02:30 PM
how wide are you rims?
i had 205 on a 7" rim, but it was bad!! now i have 195 on these rims and its so much better. No wierd worn out tires anymore... 5/2018 BMW F22 Coupe 1/1985 Toyota AE86 Levin Coupe |
01-02-2007, 02:37 PM
DJexor Wrote:how wide are you rims? 195/60/14" in 14x7 konig rewind 0 offset... ![]() Regards ![]() |
01-02-2007, 02:52 PM
Abe Wrote:dxaqta Wrote:for grip driving i run: i think 6/4 will work better as i belive 5kg rears will cause oversteer, this could be dialled out with damper adjustments, but i think a 4kg will work better... however, i think you need to look at the other areas that i stated above, why spend money on new springs when u can play with ur dampers for free!!! or get a wheel alignment for 20$!!! even if it doenst work u will lern something about ur suspension ![]() and what i have stated above is mostly from personaly expereince and from speaking to knowlegable indivduals here is a pic to prove it ![]() ![]() |
01-02-2007, 02:53 PM
abe, konig's 14" offset is -9.
I don't know your kind of driving ability but when I fitted my limited slip differential I noticed a large increase of understeer. I understood that I needed to change my driving style to reduce this handycap. Best regards |
01-02-2007, 03:03 PM
apardal Wrote:abe, konig's 14" offset is -9. Yes of course, when I put the lsd I Know i will have more understeer, and I know I need change my drive style... but the understeer is more hevy than other cars whit my lsd, and If this understeer can be change... why not change it? if I prefer a car only a bit underster or neutral... My driving ability... I don´t know but not is the worse Regards ![]() |
01-02-2007, 03:08 PM
lsd causes fuck all understeer.. u need to get that out of ur head.. there is something wrong with ur suspensino setup
have u tryed any of our sugestions???? |
01-02-2007, 03:16 PM
dxaqta Wrote:here is a pic to prove it ![]() ![]() I don´t have problems change the spring rates, because when you buy coilovers K-sport, they have a suport of springs a lot cheaper... I can buy 2 springs for around 25 € ![]() But this evening i can go to try whit a new set up of alignment.... and if it work good the problem are finish... if don´t work we know that I need search the problem in other part of the car.... at this moment, I think put dxaqta's alignment: for grip driving i run: Camber: -3.0 Castor: +4 degrees Toe: 0 Other setup or suggestion? Regards ![]() ![]() |
01-02-2007, 03:18 PM
u wont get +4 degree with stock castor rods and with 195/50/15 tyres it rubs on your front bar i had to cut mine
01-02-2007, 03:28 PM
BTW..strong LSD's will push the car into understeer..it's a matter of driving the wrong way. It will lock up..driving bioth rear wheels (which causes the car to try and go straight). If your front tyres are not up to the task, they will be overpowered and pushed into understeer.
Possible turbo setups for the 4age. | wannabeadrifter | 3 | 4,838 |
10-29-2009 06:15 AM Last Post: wannabeadrifter |
what do you use like suspensions ? | Spy | 40 | 44,843 |
04-14-2009 10:20 PM Last Post: Uzelac |
What are your ignition timming setups? | Rasteirinho | 1 | 3,106 |
02-27-2008 08:42 PM Last Post: Rasteirinho |
Electric fan setups | Ivan141 | 22 | 26,899 |
01-05-2005 10:55 PM Last Post: KristianAE86 |
