Swapping...
02-07-2008, 07:07 PM
Swapping...
Good choice, the GEO's came with the high compression 4age if i'm not mistaken...
BTW Apolan, miata's do have a nice transmission, but the engine's are real fuel guzzlers, and less interesting than 4age's imho.
02-07-2008, 07:32 PM
Swapping...
I love the RX7 trans but it's much heavier than the T50.
The Geo has the Red & Black Top. I would like to go with very high compression- any suggestion?
Thanks,
Vin
02-07-2008, 08:41 PM
Swapping...
wiseco pistons or some other aftermarket brand will do the trick...or if you want to stay cheap, shave the head and use a thinner headgasket.
02-07-2008, 08:50 PM
Swapping...
I used to do a wacky trick- lapping the head to the block and not using a head gasket Smile It only works if the head gasket isn't used to block passages.
What do you think?
02-07-2008, 08:54 PM
Swapping...
What the thinnest head gasket I can get and can I use pistons from a small port to increase my compression?
Thanks,
Vin
02-08-2008, 12:58 AM
Swapping...
The intake manifold doesn't say T-VIS, so I confused...
02-08-2008, 01:49 AM
Swapping...
Only the early bluetops had TVIS intakes. It just confirms that you have either a red, silver or blacktop 4AGE.
Nice going on the mpg front. Anyone can spin an engine to a gazillion rpm and make horsepower. It takes creativity and knowledge to make it fue efficient as well. Good luck!
02-08-2008, 03:25 AM
Swapping...
Thanks for the encouragement!
I just took some pics, it seems that I have a Red & Black top small port. It's everything I wanted except for MAP.
btw NoHachi, I may use water injection without forced induction Smile
I'm going to start extracting the engine- is there a tutorial on what can be trashed from the fuel/emissions system?
02-08-2008, 04:39 PM
Swapping...
Red & Black Top; red lettering on one half and black on the other.
It looks like this: http://www.freewebs.com/shatonapples...om%20above.JPG
02-08-2008, 07:20 PM
Swapping...
vin Wrote:Bored... you may be right...
I just got rid of my TDi Sad
I had put in a European computer in it, had the computer reprogrammed, put in a smaller turbo, bumped the compression, and had a pipe from the turbo back. I was getting 65 mpg on the highway, at 70 mph. I also drove the thing into the ground. So now I want to do a gas high MPG. I've been doing high MPG cars since gas was $.85, so I don't think I'm going to stop now
I just bought a donor car last night. A Geo Prizm GSi with a nice 4AGE.
If only fuel was that cheap! Paying about $2.20 per litre right now. Sad Averaging 20mpg round town.
  Swapping headlamp lenses Sanity Clause 10 9,236 01-17-2008 09:59 PM
Last Post: Jezza_hr
