Swapping...
02-07-2008, 07:07 PM
Swapping...
Good choice, the GEO's came with the high compression 4age if i'm not mistaken...
BTW Apolan, miata's do have a nice transmission, but the engine's are real fuel guzzlers, and less interesting than 4age's imho. FABRICA MI DIEM, PVNC! |
02-07-2008, 07:32 PM
Swapping...
I love the RX7 trans but it's much heavier than the T50.
The Geo has the Red & Black Top. I would like to go with very high compression- any suggestion? Thanks, Vin |
02-07-2008, 08:41 PM
Swapping...
wiseco pistons or some other aftermarket brand will do the trick...or if you want to stay cheap, shave the head and use a thinner headgasket.
02-07-2008, 08:50 PM
Swapping...
I used to do a wacky trick- lapping the head to the block and not using a head gasket It only works if the head gasket isn't used to block passages.
What do you think? |
02-07-2008, 08:54 PM
Swapping...
What the thinnest head gasket I can get and can I use pistons from a small port to increase my compression?
Thanks, Vin |
02-08-2008, 12:58 AM
Swapping...
The intake manifold doesn't say T-VIS, so I confused...
02-08-2008, 01:49 AM
Swapping...
Only the early bluetops had TVIS intakes. It just confirms that you have either a red, silver or blacktop 4AGE.
Nice going on the mpg front. Anyone can spin an engine to a gazillion rpm and make horsepower. It takes creativity and knowledge to make it fue efficient as well. Good luck! A wheel to steer the front of the car A pedal to steer the rear |
02-08-2008, 03:25 AM
Swapping...
Thanks for the encouragement!
I just took some pics, it seems that I have a Red & Black top small port. It's everything I wanted except for MAP. btw NoHachi, I may use water injection without forced induction I'm going to start extracting the engine- is there a tutorial on what can be trashed from the fuel/emissions system? |
02-08-2008, 04:39 PM
Swapping...
Red & Black Top; red lettering on one half and black on the other.
It looks like this: http://www.freewebs.com/shatonapples...om%20above.JPG |
02-08-2008, 07:20 PM
Swapping...
vin Wrote:Bored... you may be right... If only fuel was that cheap! Paying about $2.20 per litre right now. Averaging 20mpg round town. |
Swapping headlamp lenses | Sanity Clause | 10 | 9,236 |
01-17-2008 09:59 PM Last Post: Jezza_hr |
