T3 springs
04-11-2005, 07:48 PM
T3 springs
What springs are on the T3 rear coil-overs and other rear coil-over springs? 2.5"?
Broken down 1984 Trueno HB ![]() |
04-12-2005, 09:58 PM
T3 springs
Email Gabe Tyler and he should help you out. Or Luis at paradise racing
You have by far the ugliest hachi on the nicest rims in the world -Mux213 |
04-12-2005, 11:32 PM
T3 springs
Isn't that just the groundcontroll stuff? In that case: 2.5"
04-13-2005, 12:21 AM
T3 springs
What's the 2.5" stand for? Inner spring or the middle of the spring?
04-13-2005, 10:15 AM
T3 springs
Odly enough, that varies from manufacturer to manufacturer. I've been looking around for springs for the volvo and almost went crazy. I.D, OD MD, I've everything fly past.
Usually though, a 2.5" spring means 2.5" O.D or outer diameter. And 99% of 2.5" springs are interchangeable. A wheel to steer the front of the car A pedal to steer the rear |
HKS valve springs | totta Crolla | 3 | 2,484 |
Springs from other vehicles?? | FanIsHere | 16 | 15,309 |
05-17-2016 09:12 AM Last Post: FanIsHere |
3rd door support gas springs (stay) - worn out | max_ae86 | 5 | 6,456 |
09-01-2013 03:20 PM Last Post: Jezza_hr |
Valve springs length | Vil | 4 | 6,073 |
04-04-2013 07:41 PM Last Post: oldeskewltoy |
Maybe problem with TRD shock absorber and springs | Mattolo | 22 | 21,709 |
10-15-2011 07:40 PM Last Post: zenki |
