T50 Gearbox max power
12-17-2007, 06:58 PM
Hello
I'm trying to find what is the max torque and max power that a T50 gearbox can admit.
Thanks a lot!
[Image: AEU86 AE86 - T50 Gearbox max power]
http://ae86kouki.googlepages.com
12-17-2007, 08:25 PM
500hp if you drive carefully
100hp if you don't
its more about how you threat the box not the amount of torque or hp
12-25-2007, 01:49 PM
Il est dit généralement que la T50 tien les 200cv j'en sais pas plus.
Si ca rest de l'athmo c'est bon. si c'est en turbo (donc plus de couple) ca devien assé chaud.
SR Team
BURN THE RUBER NOT YOUR SOUL!
12-25-2007, 08:02 PM
Same as Boomex said, I think that the T series gearbox and diff will stand with the 200bhp NA mark,
If you'll use a turbo, it's another problem because of the torque more than the power, I'm not sure but 20mkg will be the limit...
If more you'll have to use W series or S series.....
1982 Toyota Corolla KE70
1992 Subaru Legacy BF5T
12-26-2007, 12:22 AM
I´ve driven quite long with my 254hp / 371Nm 2T turbo engine with T50 trans. With proper gear shifting it will survive. But you can break it with stock 2T and 75hp / 140Nm.
blacktop beams 3S-GE carina
12-26-2007, 11:19 AM
Ok thanks for reply Cool
It is for a turbo setup (T2Cool, i don't know what will be the torque.
I'll put 0,5b (7psi) on first and see what happen Smile
I think I will have 160 or maybe 170 horsepower.
When you say 200HP, it is at wheel or flywheel?
12-26-2007, 12:15 PM
170 hp/250 Nm can de T50 handel easy Smile
Starlet p8 si turbo @ 1.0 bar grey 6,4 sec-> 100
Starlet P9 si turbo @ 1.2 bar black 5,8 sec-> 100
KTM 950 SE ->100 3,2 sec 105 Db Tongue
xt660r ->100 4,5 sec
BMW 1100 GS->100 4 sec
12-26-2007, 03:55 PM
diz9 Wrote:Ok thanks for reply Cool
I have my ae with a a silvertop turbo at 11psi , no problem with the the tranny I purchase the car that way and the setup has been for a while no problem at all. I haven’t gone to the dyno but at least it has 200hp at the wheels
12-28-2007, 02:16 AM
if u take it easy with it, it should be fine... just dont do massive clutch dumps, big clutch kicks or munch the gears...
i would change to a w -series as all the above things are the fun bits of driving a car Smile
  Anyone got Max Orido's Magical Fuse? banpei 7 5,292 02-08-2024 11:09 AM
  T50 gearbox totta Crolla 3 3,301 02-25-2022 02:35 PM
Last Post: Project D
  T50 TRD gearset DidiDex 7 10,596 09-12-2019 07:36 PM
Last Post: DidiDex
  4A-GE bellhousing on a 20 spline T50 The Doctor 2 7,756 09-30-2016 03:38 PM
Last Post: The Doctor
  T50 gearbox - TRD 2nd and 3rd gear hachirokkos 3 7,415 11-27-2015 10:06 AM
