T50 gearbox leak
05-24-2011, 07:30 PM
T50 gearbox leak
I thought this was the rear oil seal leaking but it turns out the gearbox is leaking from behind the release bearing retainer.
It looks straightforward to fix but is there anything I should watch out for when doing so ? Anyone seen this problem before ? Thanks, TC An analogue brain in a digital World |
05-28-2011, 12:13 AM
T50 gearbox leak
Should be straight forward, i just ordered the seal from Toyota aswell as a gasket thats required when changing the seal.. 4 bolts once the box is off!
I've had two gearbox's leak like this, both times i found the engine had no spigot bearing in the back of the crank as someone had put FWD motors in, so perhaps get a spigot bearing too, if required. Driftworks - JSPFab.com - DangerStyle - NightSpirit |
05-28-2011, 06:46 PM
T50 gearbox leak
Mine was leaking from the gasket and the oil seal looked ok.
Definately has a spigot bearing, fitted it myself. I can see how the seal could get damaged if the bearing is missing though. An analogue brain in a digital World |
T50 gearbox | totta Crolla | 3 | 2,678 |
02-25-2022 02:35 PM Last Post: Project D |
T50 TRD gearset | DidiDex | 7 | 9,316 |
09-12-2019 07:36 PM Last Post: DidiDex |
4A-GE bellhousing on a 20 spline T50 | The Doctor | 2 | 7,141 |
09-30-2016 03:38 PM Last Post: The Doctor |
T50 gearbox - TRD 2nd and 3rd gear | hachirokkos | 3 | 6,816 |
11-27-2015 10:06 AM Last Post: Project D |
T50 Gearbox, Fragile ! | hachirokkos | 10 | 12,544 |
11-12-2015 12:06 PM Last Post: S.K. |
