T50 weird gear set What´s going on?
08-13-2012, 09:08 AM
fax0815 Wrote:Call me fussy, but I think the final drive does have a big effect on what I described. Imagine this AE86 doesnt run the advised 5,3 ratio, for instance a 4,3 or a 4,7. you might want to read this thread: http://hachiroku.net/forums/showthread.php?t=17462 might come a bit late but still valuable info in there. My recommendation, if you still have the OEM stacks, fit them! if you can make the airbox work, fit it too. And don't worry it's all fixable with the right approach. I've gone through countless discussions with many people, exactly on that problem: tuning and engine and neglecting how it will be used to optimize driveability. This is not a AE86 or 4AGE issue this is a general one I utterly despise after more than 10 years of dealing with it. All in all sorry for the rant/teacheresque like post. give us some more details (dyno run would be best but we can work it out with your feel too) and I'm sure the community and I will be able to improve your situation. AE86 ex-daily |
08-13-2012, 12:10 PM
fax0815 Wrote:That gotta be the 33030-AE851! Look at the drop of revs with 5.3 and 4.3 between gears. Same. Speed is different, that's up to final drive. And that is certainly isn't 33030-AE851. Nothigs specific about it, standard gearset aimed for racing with long 1st and close 1>2>3>4>5. |
08-13-2012, 04:50 PM
OEM gearbox, shifting @ 8000 [u:78bb0652f6]if you don't loose speed[/u:78bb0652f6]:
1->2: 4510rpm 2->3: 5476rpm 3->4: 5780rpm 4->5: 6888rpm Same thing but with TRD AE851: 1->2: 5752rpm 2->3: 5855rpm 3->4: 5780rpm 4->5: 6888rpm Same thing but with TRD AE811: 1->2: 5492rpm 2->3: 5949rpm 3->4: 6695rpm 4->5: 7088rpm |
T50 gearbox | totta Crolla | 3 | 2,761 |
02-25-2022 02:35 PM Last Post: Project D |
5th gear issue | r.ave | 1 | 2,756 |
03-14-2021 08:52 PM Last Post: Ivan141 |
T50 TRD gearset | DidiDex | 7 | 9,566 |
09-12-2019 07:36 PM Last Post: DidiDex |
ring gear bolts | DJexor | 3 | 5,678 |
12-26-2016 10:56 PM Last Post: totta Crolla |
4A-GE bellhousing on a 20 spline T50 | The Doctor | 2 | 7,236 |
09-30-2016 03:38 PM Last Post: The Doctor |
