TOYGT - #AE86#
05-30-2008, 05:13 PM
TOYGT - #AE86#
L'auto:
montage de petit mano Modifications The most important chassis: - Engine compartment solder Drawing-hunting and adjustable uniball. - steering rods ralongé and uniball. - Building a bridge strengthened. - Barre panhart strengthened and adjustable. - D2 suspension street with camber plate (for the camber). Anti-Barre rapp TANABEE before. -2 Rims 15 SSR longchamps AND negative. -2 Wheels 14 watanabee. -4 Rims in 15 sports max, ca mounted S-DRIVE Motor: - repair - collector on-line measure Exhaust-band - clutch exedy stage 1 Inside: -Bacquet carbon-BORDER -BORDER-Harnes - Slide Special AE86 -4-pole point -ORECA-wheel hub with detachable -WARNER-gauge STEWART Oil pressure Oil temperature water temperature Account towers with shift light. Last work done: Painting-Neuve - wing fired -satin black hood - door jamb satine and black wing black satin. - Panel door painted in black with satine lisserais red. -Arceau-painted in black satin. Coming soon: Engines: I do not no a 4a-gze or 4a-ge itb etc? - 4A-GZE 4th gen 170cv Pulley-vilo to increase pressure compressor 190cv Prepa-top engine (valve, guide, etc.) Brakes: Pending the engine SARD-platelet type-c - Avia hoses - Liquid RBF600 Disk-origin - Search for a big brake kit Cockpit: - Door panels etc. repainted in black satin with red finished lisserais Hubs-wheel painted in black satin finish arch-painted in black satin - shifter TRD Bacquet carbon-border for the passenger Harnes-border Idem - Manufacturing plate for plugging holes to empty black satin Voila everything |
05-30-2008, 07:29 PM
TOYGT - #AE86#
N1 car (someone translate plz ?)
05-30-2008, 07:32 PM
TOYGT - #AE86#
Not the best but much better (Google translate)
Translation: French » English The most important chassis: - Engine compartment solder Drawing-hunting and adjustable uniball. - steering rods ralongé and uniball. - Building a bridge strengthened. - Barre panhart strengthened and adjustable. - D2 suspension street with camber plate (for the camber). Anti-Barre rapp TANABEE before. -2 Rims 15 SSR longchamps AND negative. -2 Wheels 14 watanabee. -4 Rims in 15 sports max, ca mounted S-DRIVE Motor: - repair - collector on-line measure Exhaust-band - clutch strengthened exedy stage 1 Inside: Bacquet carbon-BORDER BORDER-Harnes - Slide Special AE86 4-pole point ORECA-wheel hub with detachable WARNER-gauge STEWART Oil pressure Oil temperature water temperature Account towers with shift light. Last work done: Painting-Neuve - wing fired satin black hood - door jamb satine and black wing black satin. - Panel door painted in black with satine lisserais red. Arceau-painted in black satin. Coming soon: Engines: I do not no a 4a-gze or 4a-ge itb etc? - 4A-GZE 4th gen 170cv Pulley-vilo to increase pressure compressor 190cv Prepa-top engine (valve, guide, etc.) Brakes: Pending the engine SARD-platelet type-c - Avia hoses - Liquid RBF600 Disk-origin - Search for a big brake kit Cockpit: - Door panels etc. repainted in black satin with red finished lisserais Hubs-wheel painted in black satin finish arch-painted in black satin - shifter TRD Bacquet carbon-border for the passenger Harnes-border Idem - Manufacturing plate for plugging holes to empty black satin Voila everything 1985 AE86 (ハチロク) Levin - Summer time daily driver |
05-30-2008, 07:42 PM
TOYGT - #AE86#
It's rectified
