TRD Adjustable shocks
05-17-2006, 11:32 PM
How are the shocks adjusted, i have located the screw. Are they adjusted with the shock extended or compressed or at ride height ? the dial is numbered on the shock is 1 soft and 9 hard ? or is it the other way around ?
05-21-2006, 03:04 PM
can anyone answer this ? or have i asked a stupid question ?
05-21-2006, 03:16 PM
It doesnt matter, just twist the dial to adjust damping, you just use a flat screw driver to do it. There is a small arrow that points to what number of damping its set at. the higher the number the stiffer the damping.
Driftworks - JSPFab.com - DangerStyle - NightSpirit |
05-21-2006, 11:46 PM
thanks i wasn't sure. i thought some shocks had to compressed to adjust them.
rear bilstein B6 shocks 2 types what to choose? | Ryo | 5 | 3,493 |
Build your own adjustable fuel pressure regulator ;) | oldeskewltoy | 8 | 21,378 |
KONI Sports shocks for the AE86... | jondee86 | 11 | 20,954 |
Question about KONI shocks for an AE92 | Apsogos | 1 | 4,156 |
09-13-2013 07:40 AM Last Post: Apsogos |
Adjustable steering column | 4000GT | 6 | 8,685 |
07-12-2012 08:15 AM Last Post: 4000GT |
