TRD Adjustable shocks
05-17-2006, 11:32 PM
How are the shocks adjusted, i have located the screw. Are they adjusted with the shock extended or compressed or at ride height ? the dial is numbered on the shock is 1 soft and 9 hard ? or is it the other way around ?
05-21-2006, 03:04 PM
can anyone answer this ? or have i asked a stupid question ?
05-21-2006, 03:16 PM
It doesnt matter, just twist the dial to adjust damping, you just use a flat screw driver to do it. There is a small arrow that points to what number of damping its set at. the higher the number the stiffer the damping.
05-21-2006, 11:46 PM
thanks i wasn't sure. i thought some shocks had to compressed to adjust them.
  rear bilstein B6 shocks 2 types what to choose? Ryo 5 3,494 07-25-2021 04:41 AM
  Build your own adjustable fuel pressure regulator ;) oldeskewltoy 8 21,378 08-19-2018 12:08 PM
Last Post: AlexKTM
  KONI Sports shocks for the AE86... jondee86 11 20,955 09-08-2017 03:38 AM
Last Post: jondee86
  Question about KONI shocks for an AE92 Apsogos 1 4,157 09-13-2013 07:40 AM
Last Post: Apsogos
  Adjustable steering column 4000GT 6 8,686 07-12-2012 08:15 AM
Last Post: 4000GT
