TRD Head gasket P/N 11115-AE851
04-10-2008, 01:27 PM
Hello,
I found 2 TRD head gaskets in my office with the P/N 11115-AE851.
I presume they are for AE86/4AGE.
I searched for this P/N on TRD website and on google and couldn't found anything, however i think AE851 stands for AE86 parts.
Anyone can help me or have any suggestion?
Thanks,
Pedro
Keeping the AE86 alive!
04-10-2008, 06:22 PM
Those gaskets are from a LOOOOOONG time ago. I have a 9/1986 TRD parts catalog.
[Image: AEU86 AE86 - TRD Head gasket P/N 11115-AE851]
"11115-AE851 - Gasket, cylinder head 1.2mm(when torqued) material asbestoes"
Dan -
04-10-2008, 09:06 PM
give us the catalogue Oldskewlboy :wink:
04-10-2008, 10:01 PM
i might be needing one of those Tongue ( if they are for sale )
04-10-2008, 11:32 PM
yes gon... we can make a deal on them...
I also have one of those catalogues on the attic.
If it has 1.2mm is larger than the oe one, right?
04-11-2008, 12:42 AM
good for turbo or supercharger aps!
Hmmmmmmmmm The above gasket is stock thickness when torqued. The stock gasket thickness is 1.2mm Other gaskets listed are a 1.1mm a .8mm and a .5mm
also aasbestos ISN'T desireble for boost, solid metal... or mls... is ok, not asbestos If you want gaskets for boost... SCE makes SOLID copper head gaskets upto 2.4mm thick......
Dan -
04-11-2008, 11:32 AM
So this gasket is good for high compression pistons...
It should have a better resistance than the OE one...
  Oil leak (maybe a cylinder head gasket?) max_ae86 15 17,034 11-30-2013 03:59 AM
Last Post: jondee86
  4AGE Heat Shielding Intake Gasket asyrigos 11 23,822 04-01-2013 10:58 AM
Last Post: asyrigos
  Doing a 7AGE build, gasket question Snejk 9 14,238 07-15-2010 12:42 PM
Last Post: PetzK
  Head Gasket Replacement - Block Surface Question ?? juantonwan 4 5,538 06-11-2009 02:24 PM
Last Post: ZDoman
  oem head gasket thickness? Melo 6 5,890 05-22-2009 10:46 PM
Last Post: Melo
