TRD spring pressure rate??
01-07-2008, 05:10 PM
Hi
I got a second-hand TRD suspension and I'm not sure what pressure rate the springs is.. Is there some way I can finde out what the pressure rate is, fore example by measuring the wire diameter?? thanks |
01-07-2008, 06:09 PM
Try this link:
http://www.stockcarproducts.com/pstech10.htm An analogue brain in a digital World |
01-07-2008, 06:34 PM
Who did you buy them from?
01-07-2008, 08:13 PM
I dont know how accurate this is but makes sense. In the spring you can find the part number. The part number is followed by 2 digits, this digits lets you know the spring rate.
For example, a rear spring with 48231-AE801-65 on it, means 6,5 kg. CumpĀ“s Filipe Oliveira |
01-08-2008, 03:04 PM
totta Crolla Wrote:Try this link:Thanks, I'll try it and see if it makes any sense. Jan P: I belive it's from the red coupe K-POWER had years back.. Lipinhu: Thanks but unfortunately you can't see the part number on them any more.. |
Build your own adjustable fuel pressure regulator ;) | oldeskewltoy | 8 | 21,071 |
SOME 4AG valve spring specs | oldeskewltoy | 5 | 13,384 |
05-04-2015 01:17 PM Last Post: Project D |
Oil Pressure Query | Alex170984 | 2 | 5,164 |
12-11-2014 01:25 AM Last Post: Alex170984 |
Pressure gathering in fuel tank | Apolan | 9 | 14,898 |
05-18-2014 06:18 AM Last Post: chenfon |
oil pressure high | kawo | 17 | 20,406 |
09-29-2013 12:06 PM Last Post: allencr |
