Tail lights are semi-working
05-13-2006, 08:55 PM
Just a few nights ago i realised that my tail lights are not working properly. When i brake they come on fine but when i have the headlights on they do not turn on except when im braking, like when i have the headlights off.
I tried checking all the bulbs etc, just in case, but im no auto electrician.
The other thing i thought of was is this normal? Im really worried about it, i have no idea how the local constabulary will feel about it.
Insights anybody?
Current Cars:
'86 SE82 FX GT
'88 NZ New KE70 Van (Daily)
05-13-2006, 09:11 PM
Check your combinationswitch (the knob you turn on the dash) and your taillight relay (the round one in the kickpanel fusebox). If it isn't one of those your wire might be broken.
[Image: AEU86 AE86 - Tail lights are semi-working]
05-13-2006, 09:49 PM
there must be some kinda ground and + fooling around...check the light inside, where all the bulbs are attatched, give a good clean there, and give it some wd40!!
adam
05-14-2006, 12:06 AM
Does your in dash light work? If not you have a defect fuse...
05-14-2006, 03:00 AM
No, that was the other thing, the light behind the speedo doesnt work either. So you reckon its a fuse then? sounds like i have some investigating to do..
Current Cars:
'86 SE82 FX GT
05-14-2006, 07:14 AM
I had a look around in the fuse box, no blown fuses..
Current Cars:
'86 SE82 FX GT
05-14-2006, 11:13 AM
I'm 99% sure you got a blown fuse! Did you check the engine fuse box?
I don't remember which fuse is for taillights and dashlight, but it is the same...
05-14-2006, 12:08 PM
I didnt check engine fuse box, just the kick panel fuse box. Does anyone have a diagram of which fuse it is? i dont even know where the engine fuse box is Dumb question Banging head
Current Cars:
'86 SE82 FX GT
05-14-2006, 02:10 PM
NZ Trueno Wrote:I didnt check engine fuse box, just the kick panel fuse box. Does anyone have a diagram of which fuse it is? i dont even know where the engine fuse box is Dumb question Banging head
say what!?!????
its the black box just above the battery :wink:
Jón Mar
"T3 is good. I'd go with them. And they're red. Red goes faster..."
'87 AE86 3dr - Black
'87 AE86 3dr - Red
'88 AE92 5dr GTi - Black
'95 ST205 - Red - sold
05-15-2006, 08:14 AM
Dont make fun, i hadnt ever looked for it. Is there a way for a fuse to be defect other than being blown? i have now checked every fuse in the kick panel and engine fuse boxes and all are fine.
I guess i will have to get in an auto electrician..
Current Cars:
'86 SE82 FX GT
  Brake lights not working takumi_mt 2 639 03-07-2024 03:42 PM
Last Post: takumi_mt
  Tail light wiring... Mylesmck 4 886 02-02-2024 12:36 PM
Last Post: Mylesmck
  Can you seperate trueno kouki bumper lights into zenki bumper lights? gh0st 17 7,642 12-19-2021 11:58 PM
Last Post: gh0st
  working out compression ratios kazi 2 3,500 07-16-2019 08:22 PM
  Dash lights not working. kazi 5 6,872 05-09-2017 12:31 PM
