The Big Yins 86
11-21-2005, 01:21 PM
The Big Yins 86
Only had the car a few days and I have discovered sme nice surprises on it which is saving me money.
It already has a 4-1 manifold Full Sports Exaust Adjustable shocks front and back Front Adjustable Camber Front strut brace and a HKS Mushroom Filter I dont have any plans to strip the car out........... yet but that may come in the future you never know I might put a rear cage in it. Already ordered are, Toda Racing Cams ECU Toda N1 chip and a SAFC Going to Order a clutch in next few days Parts still to get FORGED PISTONS- (JE) PULLEYS-) (hks) VALVE SPRINGS (hks) lowering Springs 40mm springs Bilstein i think Car goes into my local Jap specialist Hypertech clicky on Wednesday for a full check over Then on thursday it goes into a local body shop to get the 2 rear arches sorted, just under the boot and undear the rear passnger window, all rust spots so gettin it all done just now before it gets worse |
11-21-2005, 01:22 PM
The Big Yins 86
That car is such a beauty! Sounds like you gonna take good care of her to, good boy!
11-21-2005, 02:19 PM
The Big Yins 86
Howdy Yin,
I have some nice fidanza cam gears that I could sell you. They are brand spanker new and great quality. They are still in their shiney new boxes. They are at least as good a quality as the HKS ones. Let me know if you are interested. Regards Ian. |
11-21-2005, 02:27 PM
The Big Yins 86
Fidanza Adjustable Cam Gears
Regards Ian. |
11-21-2005, 05:03 PM
The Big Yins 86
i just wanna ask, why is it good to have all those ground leads? arent the stock ones alright? i am also missing some ground leads (like the hood-2-ground, and perhaps some other. everything works fine. i've seen people really invest in taht so i would like to know whats the big deal?
11-21-2005, 06:03 PM
The Big Yins 86
It is said that they provide a shorter groundpath, which would have positive effects on the ignition and maybe even injectors. I'm not too sure if it really helps though. The most reputable maker of these hyper-ground or whatever they are called kits is SUN auto from japan. They ask quite a bit compared to the ebay crap but they do have dyno sheets showing a slight improvement.
11-22-2005, 01:34 AM
The Big Yins 86
they were already on the car when i bought it, going to a rollin road day on thew 8th december to find out what she is putting down, i want to know before i start to mod her
11-22-2005, 12:08 PM
The Big Yins 86
well here is a picture of the cams, bought them fr $575 so £340 bloody bargain consideruing they are £270 + vat here in the uk
11-23-2005, 07:20 PM
The Big Yins 86
my car just came back from its checkover and here is some of the stuff i need done
getting a organic clutch needs all fluids changed, brakes, need checked and cleaned, possbaly replaced, spark plugs, leads, both drive belts cracked and worn, one of my rear shockies is seized, PAS steering belt pretnsioner badly worn(squeel) and a few other things needing done lol, so this stuff is more important |
11-23-2005, 11:11 PM
The Big Yins 86
both front A/R/bar links worn
slight play on both front hub bearings slight play on o/s/r rack end slight play on o/s/r track rod end HKS filter needs its filter replaced (a green one) both drive belts worn and cracked PAS steering belt tensioner bearing badly worn oil level just above min recomend changing all fluids N/S/R dampening adjuster seized Clutch Assembaly Required ASAP slight whine from diff(nothing to worry about) all breaks require strippingand cleaning (possably need to replace dics and pads) all work to be started 2morrow |
(Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 2,939 |
AE86 N2 (big update) | 86Pilot | 110 | 137,307 |
09-06-2013 11:33 AM Last Post: Apsogos |
3AGE-AE86 NZ [big pics warning!] | WELL | 9 | 13,724 |
04-17-2007 07:48 AM Last Post: domi |
Big brakes on my SE-86 at last. | Billzilla | 12 | 15,483 |
09-13-2005 04:07 PM Last Post: Billzilla |
