The old Crown Wheel and Pinion whining questions...
01-10-2011, 01:42 AM
I've had a look around and I've found two topics that somewhat contradict one another when looking for the answer to this question.
I just had my crown wheel and pinion replaced after my last one blew up (everything thoroughly cleaned, bearings replaced and backlash set). There are two things I have noticed after driving about 30 miles so far. - The wheels are a little harder to turn by hand than they used to be. Would this be down to bedding in with the new crown wheel? Obviously there isn't much change when turning the prop by hand due to the weight difference etc - There is a slight whining when coming to a stop (the sound of a vacuum cleaner being switched off) and when maintaining a consistent speed at about 30-40mph. Is this normal during the running in procedure or is something not right with the set up? I also noticed around here there were running in recommendations for the crown wheel, which I saw AFTER driving the car ![]() ![]() |
01-10-2011, 02:02 AM
Bearings will be be a little tighter than before due to pre-load. They will
loosen up a bit as they bed in. I don't even know the recommended break-in procedure for a new CW&P, but gears always need a period of light load running to burnish the mating surfaces and let them bed to each other. So I would say just take it easy to begin with... no heavy torque loading... just normal "granny style" driving for a while. Then raise the rpms and a bit more loading by running thru the gears at less than full throttle until you have 1000 km or so on the diff. Change the oil and start load cycling in earnest ![]() Cheers... jondee86 |
01-10-2011, 02:13 AM
As always Jondee, your informative and quick responses are highly appreciated
![]() I'll change the oil at the end of the month for something higher grade and again at the end of February, hopefully it will all bed in with minimal noise. I just wanted to be sure that what I'm hearing/feeling is normal after installing a new CW&P set. |
01-10-2011, 02:27 AM
Yeah... I just dug up those recommendations from 20Vwill... I knew I had
seen them somewhere ![]() mentioned by some gear manufacturers. Most times that will happen as you go and have a beer after your first test drive :-P Cheers... |
01-10-2011, 03:38 AM
Jezza_hr Wrote:I just wanted to be sure that what I'm hearing/feeling is normal after installing a new CW&P set. NO, it is not normal and does not need any specific running/bedding in and it will not get better, only worse or it will just stay almost the same for a looong time if its bad setup isn't too far off. The new bearing's pre-load may have been setup on the high side so it will have some resistance for the first few hours or so. It will be generating some extra heat. Don't plan on climbing Pikes Peak or pulling a trailer for 1000km/600mi. |
01-10-2011, 09:29 AM
allencr Wrote:Jezza_hr Wrote:I just wanted to be sure that what I'm hearing/feeling is normal after installing a new CW&P set. So, wouldn't the bearings require a minor amount of bedding in to calm the resistance and noise? |
01-11-2011, 12:55 AM
Jezza_hr Wrote:So, wouldn't the bearings require a minor amount of bedding in to calm the resistance and noise? Yes, they can use some run-in so don't pull a trailer the first 50k & change the lube at 1000k. There may be a VERY light paste like cover on the magnet, it's grey and doesn't look like the metal it is, more like some modeling clay. Anything more then that signifies trouble. The noise you hear is not from the bearings if it is most noticeable during light throttle level ground cruising, it turns on & off with slight throttle changes, and disappears with heavier throttle. |
01-11-2011, 02:33 AM
Did you buy a new Cw+P?
Reucing of an old one could cause this, too. 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
01-11-2011, 09:41 AM
Yes, it's a brand new CW&P. I've spoken with both Weir and Darren McNamara. They have both advised me that this is likely due to pinion depth (or preload of bearings) so I'll be taking it apart again at the weekend to check it all through.
20v Silvertop - New Haltech ECU & Couple of questions | 20valver | 10 | 5,039 |
Windscreen stoopid(?) questions.... | Mylesmck | 7 | 2,558 |
04-30-2024 09:46 PM Last Post: Mylesmck |
Brake Bias Questions | mad.matt | 10 | 13,509 |
01-03-2019 04:54 AM Last Post: mad.matt |
DIY: a quick outline on why & how to set pinion angle. | assassin10000 | 9 | 20,721 |
Rebuild rear disc brakes toyota crown ms112 axle | bozu | 0 | 4,335 |
