Max ignition Advance?
09-30-2007, 10:37 PM
Just wondering what is the maximum ignition advance on a large port 4AGE, I'm heading to the rolling road next week, finally getting the car set up on the ITB's. I am currently running 31 degrees advance at full load, high revs.
Cheers
Ivan
1972 MG Midget - AE86 Engine, Ford Anglia Axle - Escort LSD - Live the Dream!!1
10-01-2007, 07:56 PM
on my blacktop , when it was na, i used to run 38 degrees at 8500 rpm, with the lowest around 6k rpm, that was around 33 degrees,
This was on 98 octan, but i think that blacktop can run a bit more advance over the bigport 16v
/Skassa
Any fool can go fast in a straight line.
VEMS Blacktop 4AGTE20V 272hp/350nm
"""www.turbotoys.dk"""
  Ignition switch plug and wires Blaze0010 3 383 11-25-2024 12:29 PM
Last Post: Blaze0010
  Anyone got Max Orido's Magical Fuse? banpei 7 3,595 02-08-2024 11:09 AM
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 13,642 07-18-2019 03:52 PM
Last Post: oldeskewltoy
  extracted freedom ecu 16v ignition map ditn 7 8,950 08-22-2016 10:01 AM
Last Post: ditn
  4AGE 20v Ignition Lead Length mad.matt 3 6,695 10-01-2014 03:43 PM
