Timing Cambelt 4 AGE
07-11-2006, 01:09 PM
Dear all,
Since Oktober last year I am driving a 4 age powered kit car and I was wondering how to time the cambelt correct. Everything is clear except for the two dots on the inlet and outlet camgears. They should not be up top,
but one tooth inward, is that correct ?
I do not have any markings, only the ones on the camgears ! ( I am not using a cap yet )
Thank you in advance !
Best regards
Jos
Netherlands
07-11-2006, 01:29 PM
I'm afraid it's not really possible to time it properly without the backing plate installed. They should indeed not be exactly at the top, but you cant say one tooth this or that way because they both line up differently (not the same angle for both cams). You could try finding a picture of the camgears at TDC, but it would still be possible to mess up.
Just find yourself a backing plate, it's not that difficult to find 4age stuff around the netherlands. Personally I think it's a bit silly to leave the covers off, exposing the timing belt to road debris..
07-11-2006, 01:40 PM
Well in case he can't find a backing plate, does this help?
[Image: AEU86 AE86 - Timing Cambelt 4 AGE]
07-11-2006, 02:25 PM
hmm...looking at it like that it does look like 1 tooth towards the middle is about right..BTW I have an extra backing plate at home somewhere, and I'm sure a lot of other guys have spares around as well.
07-12-2006, 08:42 AM
Thanks a lot guys !
Changed the outlet camgear and now everything runs fine again Thumbs up!
Thanks to the picture we coul also count the number of "free" teeth on the belt between the markings to make sure everything was set ok.
Thanks for the offer Ivan regarding the backing plate. Will remeber it if necesary.
Best regards
Jos
  Starting problems 4-AGE kouki Hanzo 3 2,838 08-31-2021 06:20 PM
Last Post: totta Crolla
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 14,113 07-18-2019 03:52 PM
Last Post: oldeskewltoy
  4agze timing leon205gti 11 14,125 04-07-2017 03:10 AM
Last Post: jondee86
  Toda timing info - with good general 4AG timing info too oldeskewltoy 0 4,410 11-05-2016 01:34 AM
  Cambelt Snapped Alex170984 12 12,923 06-26-2014 04:44 PM
