Tokiko Hp & Eibach & Cusco 1.5 RS & koni Sport
05-16-2006, 06:44 PM
Hello.
My ae86 have rear koni sport and OEM springs and front shocks. I buy 4 tokiko HP & 4 Eibach springs & cusco rs 1.5. a few days ago, I use my ae every day but is my funny car. I like a tougue car, 50%drift 50%grip 50% Rallycar ![]() ![]() Anybody put cusco 1.5 rs? I,ll have to cut my axels? Thanks ![]() |
05-16-2006, 10:22 PM
Hey Abe,
Hmmm choosing between koni and tokico, thats a hard choice. I've got koni's all round and am very satisfied but I heard tokico's are very very good aswell. If I am not mistaken the tokico's are adjustable while mounted on the car which is a real plus over koni's especially if you want to adjust them depending on what you are doing at that time. Soften them up for normal driving, tighten them up for drift, playing around with changing front to rear ratio's, etc. For koni you need to take em out to do the same, unless if you have short stroke koni's at the front that is.. Dont know about the cusco diff... Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
05-16-2006, 10:55 PM
I buy the tokiko Hp (blues) I think this model can´t be adjustable, but I,m not sure. I read tokiko blues are a bit soft than koni sport....
The tokiko HTS are adjustable and Keichi tsuchiya said that are the best shock for AE86.... but I don´t have enought money to buy it ![]() ![]() |
05-16-2006, 11:43 PM
blues aren't good go koni!
05-17-2006, 12:19 AM
I don't have the AE for drift, I want a fast car in all ground, I usually drive in small roads with holes and a lot of turns..... I had Koni Sport in other car, and i feel it a bit stiffer for this type of road... whit good ground they work very well. If tokiko only have a bit soft than koni sport I think that i'll have happy with this....
I'm thinking in put tokiko blues in front wheels and koni sport, do you think this is a good combination? I only have Koni sport for rear wheels. ![]() |
05-17-2006, 09:56 AM
Ah crap, I mix up hp and hts again, hahaha
![]() Well go for the yellow koni's they are the best, you can adjust them to soft when you need to, adjust them to hard when you want to have fun. The hp's are nice if you are on a budget, they even survive some nice track work. Great affordable shocks for a daily driver with an occasional track day. But if you want more out of your car, koni yellow or HTS is the way to go ![]() Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
05-17-2006, 10:08 AM
I have Tokico blues on my car as well. They are reasonable shocks for the price, but Koni's are better. You can use the tokico in front and koni in the back, it will give you a bit of adjustability. If you make the rear very stiff you'll have more oversteer, or you can set it up softer for more neutral handling. It's very easy to change the rear shock absorbers so you can always switch if you dont like it.
05-17-2006, 04:30 PM
yes, I think whit my cusco 1.5 way my hachi will be more understeer... and i think that tokiko in front and koni in rear can be a neutral stearing....
Cusco Powerball Headers on a NA 4AGE 16V? | JDMitch | 11 | 21,225 |
KONI Sports shocks for the AE86... | jondee86 | 11 | 20,901 |
09-08-2017 03:38 AM Last Post: jondee86 |
What is normal and low caster in Cusco camber plates?? | T_AE86 | 9 | 15,363 |
01-07-2016 02:56 AM Last Post: Deuce Cam |
Problems installing yellow koni's in my TE71 liftback | teun | 12 | 16,012 |
11-09-2013 03:01 PM Last Post: teun |
Question about KONI shocks for an AE92 | Apsogos | 1 | 4,145 |
09-13-2013 07:40 AM Last Post: Apsogos |
