Torque
01-04-2005, 09:13 PM
Torque
Can you get 180+NM from a 4ag engine? Or what is the max without going FI?
And what mods would you need?
01-04-2005, 11:04 PM
Torque
I doubt it...that's 2 liter territory.
An english fellow on club4ag is claiming such numbers, but I havent seen the dyno sheet so I dont really believe it.
01-05-2005, 12:59 AM
Torque
180 nm from a 4age turbo it :-) without FI hmmz
standard should be around 130-140nm so you should be able to get it up to 160 max i think
if you
bore it to 82mm
3xx cams
etc
will be one hell of an engine but way to expensive better take 4agze then
01-05-2005, 12:54 PM
Torque
You can get 190Nm - take a look at 4AGE engines for rallying.
I think - the major factor here was higher CR - ~11 and more.
01-05-2005, 02:04 PM
Torque
Can you get that amount of torque in the lower rev range or only from 5k and up? Because most race engines have no torque down low.
01-05-2005, 02:06 PM
Torque
Now way to get low RPM torque with NA race engine :-(
  Torque settings kazi 4 10,138 03-28-2017 12:15 AM
Last Post: kazi
  torque setting head cylinder bolts izanagi 1 6,336 05-29-2015 01:23 AM
  Need help finding an axle that can handle high hp/torque kevcov 5 8,381 04-17-2011 10:50 AM
Last Post: Prime86
  4AGE Silvertop torque setting christsang7 3 19,230 07-31-2009 06:12 AM
Last Post: christsang7
  T50 G/box tightening torque question. misterforager 2 7,469 04-20-2009 01:41 AM
Last Post: apardal
