Toyota Carina 1uzfe swap
09-07-2013, 10:29 PM
Hi all. I want to present my project.I live in Lithuania and we have done 1uzfe conversion to Carina ta60, but everything from the start. I have bought bone stock Carina
[Image: AEU86 AE86 - Toyota Carina 1uzfe swap]
And decided to put Lexus v8 in it, so I have bought JDM Toyota Soarer as donor car, took everything what was needed and sold the body to the scrap yard. Donor car:
09-07-2013, 10:41 PM
Engine out
Ordered w58 gearbox conversion kit from USA, kit included adaptor plate, flywheel, cluch kit, hydraulic bearing, hardware
As mentioned above I am using w58 gearbox from Supra, but had problem with adaptor plate, wich coused gearbox failure. Firs off all I tought it was gearbox it self, but when second gearbox blew up I have found that adaptor plate is not in centered..To make story short, seller send new adaptor plate, I bought third gearbox, putted everything together and for know it looks like it is working fine.
Front sump from lexus ls400
Engine in
Used original gearbox mount with a bit of modification
09-07-2013, 10:57 PM
For the record, know engine is in the car, every thing works. At the moment we are doing rear axel conversion.
One mornning it looked like this
Same day later:
This is how it looks know. It is funny how it's stockish Big Grin
I reused Lexus exhaust, but it is temporery
After conversion rooled it outside. As you can see I added fender mirrors
09-07-2013, 11:10 PM
Here is illustrated how correct and bad adaptor plate holes misaligned, wich coused gearbox failure..
I drove the car on the road, but it felt sluggish, then I've counted diff ration, wich turned out is around 2.20 Blush So decided to do BMW e30 rear suspention conversion. Bought e30 rear suspention, made adjustable toe and camber, put polyurethane bushes. Next step old sucker out
Today finally aligned new beam and tack welded it to the body. Next is to weld everything back together, make diff mount, put springs, redone brake pipes, put fuel tank and lines back.
For know thats it, wait for update.
09-09-2013, 08:57 PM
That diff was 4.3, or 4.1...MAX 3.9...so you made a huge mistake...Big Grin
09-09-2013, 09:17 PM
Well, I counted ratio like 5 times..
09-09-2013, 10:01 PM
So you decided not to sell it after all? Thumbs up!
AFAIK the Carina diff is either 4.1 for the manual or 3.9 for the autoboxes.
09-10-2013, 07:54 PM
banpei Wrote:So you decided not to sell it after all? Thumbs up!
Well I don't know why, but ratio is this low, I've counted it not once.
09-10-2013, 08:02 PM
Today I started to put my s13 suspension in front. I used: s13 LCA, hub, brakes, stock tension rod, Toyota Avensis coilovers, Toyota Yaris rack end.
Re-drilled top mounts for avensis coilovers:
Wheels have ET18 plus adaptor 2,5 cm, so it is ET-7, need to roll arches or need to get wheels with higher ET, or go with lot of camber Big Grin
09-11-2013, 09:00 PM
Today made to fit s13 sway bar. Stock 21mm, s13 - 25mm. And started put back other side:
  82 Carina TA63 DGealon 9 14,740 10-21-2016 04:38 PM
  Toyota Carina TA62 4A-GE 16v Redtop nyberrg 18 30,198 02-05-2016 09:40 PM
Last Post: nyberrg
  My Carina TA60 crxman 17 20,040 01-09-2016 10:17 PM
Last Post: nyberrg
  Project "Roku-ju" TA60 Carina Motax 24 39,136 03-05-2014 10:21 AM
Last Post: Motax
  McKenney's 1UZFE Kouki Levin Coupe McKenney 2 10,209 03-12-2013 04:53 AM
Last Post: McKenney
