Toyota KE70 3SGE Beams Swap - Axle reliability
02-06-2014, 04:57 PM
Hi there guys, how much work involved on fitting a pajero axle is on it?
I mean, its needed to cut out the 4 link points from ae axle and weld it into pajero one? does it come with lsd? Cheers |
02-06-2014, 05:44 PM
Ask Lajoosh in the XTR topic
AE86 GT - SR20DET BlackTop //// Trackday beater Citroen C4 Coupe VTR - 1.6HDi //// Streetcar |
02-06-2014, 08:48 PM
[Walaki]D`Lair Wrote:Put a Pajero rear axle in it, and your (very possible) problems will be gone I agree..... BUT the larger rear diff is adding substantial amounts of unsprung mass. The handling dynamics will change if you run the larger axle assembly... and that might hurt his hillclimb handling.... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
02-06-2014, 10:18 PM
210bhp will change the handling itself
04-13-2014, 12:49 PM
we are running a 3sge beams in a 780 kilo sports sedan on slicks and have broken 3sets of t series axles and stripped pinions mulitple times .
have changed over to a F series rear end and dont have any more problems ,motor is making 190 kws at the back wheels at 9000 rpm |
AE86 rear axle weight | megabob | 11 | 18,796 |
Axle width | totta Crolla | 1 | 1,071 |
Rear axle options | Dino86 | 13 | 12,891 |
Rebuild rear disc brakes toyota crown ms112 axle | bozu | 0 | 3,788 |
wider rear axle,track width,suspension questions | ditn | 6 | 8,704 |
