Toyotapartsoverstock.com
11-07-2014, 08:39 PM (This post was last modified: 11-07-2014 09:14 PM by dinkers542.)
Has anyone had any experience with http://www.toyotapartsoverstock.com? Seems like they have a decent amount of parts for the 86. They even have brand new ECU if you decide you want to spend $560 for an old ecu. Also found a GTS rear end on here although I think it is an empty housing.
GTS rearear end housing assembly
http://www.toyotapartsoverstock.com/p/TO...12181.html
Not sure If this is the whole thing but it looks like a brand new Bluetop wiring harness. Please correct me if I'm wrong.
http://www.toyotapartsoverstock.com/p/TO...12580.html
11-07-2014, 09:47 PM
I was tempted to order some parts for my headlights from them, but then I found another company (jp-carparts.com) had even the springs available. As I'm not from the US the shipping costs were not that different but I reckon if you are it would make a difference.
Also they only feature USDM parts, so for my Carina it would be hard to source parts for it via them.
[Image: AEU86 AE86 - Toyotapartsoverstock.com]
11-07-2014, 09:56 PM
(11-07-2014 09:47 PM)banpei Wrote:  I was tempted to order some parts for my headlights from them, but then I found another company (jp-carparts.com) had even the springs available. As I'm not from the US the shipping costs were not that different but I reckon if you are it would make a difference.
I will have to check them out! Little of topic here but is there large difference between USDM and JDM when it comes to the engine bay? I know that some of the mounting brackets for external parts are different but I have never known what else uses differnt parts.
11-09-2014, 03:38 PM
Biggest difference is the location of the ancillaries necessary for LHD vs RHD. Mostly to do with steering and such.
BTW: That also means for instance that on LHD cars aftermarket JDM exhaust headers won't fit or on RHD cars you will have difficulty with the stock throttlebodies on the 20v engines. But normally you should be fine I guess. Wink
User(s) browsing this thread:
