Tuned 4AGE results
09-02-2009, 04:24 AM
Post: #31
Tuned 4AGE results
oldeskewltoy Wrote:tough to get ACCURATE results when you have swapped in cams....
compression tests use a pressure, measured in #s This is based partly on piston and cylinder... but a 2nd variable is when the cam opens and closes....allowing the air in and out
LOOOONG duration cams will have "relatively" low #s
Right, I understand about all that. Just wondering if I am in the ballpark or not.
09-02-2009, 05:39 PM
Post: #32
Tuned 4AGE results
Hmmmm stock TVIS (9.4 to 1) has cylinder pressure of about 179 when new. I believe the newer non TVIS engine has cylinder pressures approaching 190, when new. Finally... I know a few people with after market parts that have cyl pressures over 200... and a few of those suffer from pre-ignition(ping) The non TVIS engines were equipped with a knock sensor, the earlier ones were not.
Making an assumption, in an n/a 4AGE application... cylinder pressures under 200 should be manageable, over 200 will be much more difficult.
Dan -
09-22-2009, 10:32 PM
Post: #33
Tuned 4AGE results
Engine: 20v Silvertop stock ecu, aftermarket map module, additional injectors +2 with additional ecu, stock internals, big intercooler, big oil cooler, t4 turbo
[Image: AEU86 AE86 - Tuned 4AGE results]
09-23-2009, 12:15 AM
Post: #34
Tuned 4AGE results
very very interesting!
**COROLLA EE80 - 4AGE 124HP**
09-23-2009, 02:02 AM
Post: #35
Tuned 4AGE results
Sgonzalez Wrote:Engine: 20v Silvertop stock ecu, aftermarket map module, additional injectors +2 with additional ecu, stock internals, big intercooler, big oil cooler, t4 turbo
Can you tell us more about your setup? It sounds kinda brave! Huh
1972 Ford Taunus (drift project)
1984 Toyota Celica AA63 (4AGE, 5MT, IRS)
09-23-2009, 10:57 AM
Post: #36
Tuned 4AGE results
Why is the A/F so rich before it really comes on boost? Nice numbers and plots though..
09-23-2009, 03:35 PM
Post: #37
Tuned 4AGE results
Ivan141 Wrote:Why is the A/F so rich before it really comes on boost? Nice numbers and plots though..
The explanation that the dyno guy told me is that before the vvt is engaged the engine opens the injectors to protect the engine, but I can disengage the extra 2 injectors between 3.5 and 4.5, I think I can correct that issue
10-16-2009, 02:29 PM
Post: #38
Tuned 4AGE results
GTRJazz Wrote:Heres mine, 4AGE 3 Rib big port, HKS 264 cams,adj pulleys, open standard plenum, MFE ECU. trust exhaust manifold,TVIS removed. Engine rebuilt in Japan so unknown CR. 133.1 HP @ the wheels
Ok another run from me this time with small port ITBs fitted no changes to the MAP.I also found the TVIS system was still working on the last run and doing a good job.
"][Image: AEU86 AE86 - Tuned 4AGE results]
Quite encouraging it made 131.9 bhp @ 6950 rpm Torque is up at 99.69 ft Ibs @ the rear wheels
Shame it ran lean so we had to stop there
AFR is better mid range
10-16-2009, 02:50 PM
Post: #39
Tuned 4AGE results
Funny how you now have a mirrored torque curve. Torque seems down over most of the rpm range, as if you had (slightly) more area under the curve with the standard inlet.
Was it worth it?
10-16-2009, 03:14 PM
Post: #40
Tuned 4AGE results
NoHachi Wrote:Funny how you now have a mirrored torque curve. Torque seems down over most of the rpm range, as if you had (slightly) more area under the curve with the standard inlet.
Was it worth it?
Yes it looses quite a lot of power below 5000 rpm as it takes the air velocity time to build in the ITBs so not so good for a road car
But mine gets most use on track where I would never drop below 5k so a good benifit for me power is 131.9 bhp at only 6950rpm instead of 133bhp at 7650rpm so when the fueling issue is fixed I will make quite a bit more reving up to 8000rpm
  Max a 16v 4AGE can be tuned to? heshan 20 54,260 04-21-2009 08:31 PM
  Silvertop burning oil - compression results Jezza_hr 3 4,617 10-18-2008 02:51 AM
Last Post: jondee86
  AE86 Dyno Results! Wraith 9 13,963 10-16-2006 09:13 AM
Last Post: Mux213
User(s) browsing this thread: 24 Guest(s)
