AE86 Dyno Results!
10-15-2006, 03:32 AM
AE86 Dyno Results!
Well I took my car to get dynoed and this is what I got.
1986 TOYOTA COROLLA SR5 Automatic A/C Powersteering 2'' Custom Cat-back exhaust, everything else 100% stock down to a OEM Toyota airfilter/Oil Filter. Max power at rear wheels using a Dynojet: 49.26WHP@3400RPM 18.2WHP@6000RPM Max Torque: 76.26@3400RPM 19.1@6000RPM I drive this car daily and these numbers are without the A/C on which takes about 5-7WHP depending on ambiant air temperature. I can get to 60MPH by the end of the on ramp (shifting at 2500RPM) and cruise at 70MPH (@2200-2400RPM) all day long and get 35MPG. ![]()
10-15-2006, 08:39 AM
AE86 Dyno Results!
Cool! Intresting results, dyno chart would be intresting for a reference base.
BR ZaX Drifting - best fun you can have in your car with your pants on! |
10-15-2006, 10:27 AM
AE86 Dyno Results!
stunning results mate
last week i dyno'd my ae86 20v blacktop(bone stock) and it did 141.8whp and 168.2 engine hp ,not bad at all
10-15-2006, 10:35 AM
AE86 Dyno Results!
I am reading 50whp...am I missing a 1 somewhere..
A stock 170hp blacktop dyno is interesting too..So far everywhere else in the world people dyno them 10-15 hp under their ratings, but dyno's around Amsterdam produce figures that are 10-15hp higher then the toyota rating. Got any 0-100km/h measurements? Should be around the 6secs mark with your gearing and hp. A wheel to steer the front of the car A pedal to steer the rear |
10-15-2006, 11:16 AM
AE86 Dyno Results!
NoHachi, SR5, not GTS
Still I would expect an SR5 to be in the 70 to 90 WHP range... Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
10-15-2006, 04:12 PM
AE86 Dyno Results!
Thats what I meant..even my 1.2l 3K kitten gets better HP then that...come to think of it, so does my moms daihatsu cuore 0.8l.
10-15-2006, 08:49 PM
AE86 Dyno Results!
mine did 51rwhp
10-16-2006, 06:28 AM
AE86 Dyno Results!
Mux213 Wrote:NoHachi, SR5, not GTS The 84-87 Corolla SR5 came with a 72HP@Crank engine. At the rear wheels brand new it should put down 50-60rwhp. My Corolla has had a recent tune up with all new toyota parts from the dealership and compression is 10psi under stock all cylinders. My buddy dynoed his 1.3L starlet and he had 42whp. heres a pic of the dyno sheet.
10-16-2006, 09:13 AM
AE86 Dyno Results!
Wraith,
My bad.. I thought the SR5 came closer to the GTS then that... My GTS did 112 whp on the Dyno earlier this year so thats alot of difference.... Still looks like your well within factory specs then so thats great! Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
| Tuned 4AGE results | irishtwincam | 52 | 107,337 |
07-19-2013 10:30 PM Last Post: makkuro |
| Silvertop burning oil - compression results | Jezza_hr | 3 | 5,663 |
10-18-2008 02:51 AM Last Post: jondee86 |
| Ignition advance, Dyno and Detonation | apardal | 10 | 17,830 |
04-21-2008 11:02 AM Last Post: KrizKH |
| Dyno proven header for AE86 ????? | jondee86 | 10 | 16,363 |
03-27-2008 05:15 PM Last Post: oldeskewltoy |
| Wierd Dyno result | Knudsen | 25 | 25,005 |
05-05-2005 06:16 PM Last Post: Knudsen |
![AEU86 AE86 - AE86 Dyno Results! [Image: AEU86 AE86 - AE86 Dyno Results!]](http://i9.tinypic.com/2qicz05.jpg)
![AEU86 AE86 - AE86 Dyno Results! [Image: AEU86 AE86 - AE86 Dyno Results!]](http://www.driftparts.nl/Eric/Spaanbanaan.jpg)
