AE86 Dyno Results!
10-15-2006, 03:32 AM
AE86 Dyno Results!
Well I took my car to get dynoed and this is what I got.
1986 TOYOTA COROLLA SR5
Automatic
A/C
Powersteering
2'' Custom Cat-back exhaust, everything else 100% stock down to a OEM Toyota airfilter/Oil Filter.
Max power at rear wheels using a Dynojet:
49.26WHP@3400RPM
18.2WHP@6000RPM
Max Torque:
76.26@3400RPM
19.1@6000RPM
I drive this car daily and these numbers are without the A/C on which takes about 5-7WHP depending on ambiant air temperature. I can get to 60MPH by the end of the on ramp (shifting at 2500RPM) and cruise at 70MPH (@2200-2400RPM) all day long and get 35MPG.
[Image: AEU86 AE86 - AE86 Dyno Results!]
10-15-2006, 08:39 AM
AE86 Dyno Results!
Cool! Intresting results, dyno chart would be intresting for a reference base.
BR
ZaX Thumbs up!
10-15-2006, 10:27 AM
AE86 Dyno Results!
stunning results mate Hurray!
last week i dyno'd my ae86 20v blacktop(bone stock) and it did 141.8whp
and 168.2 engine hp ,not bad at all Hurray!
10-15-2006, 10:35 AM
AE86 Dyno Results!
I am reading 50whp...am I missing a 1 somewhere..
A stock 170hp blacktop dyno is interesting too..So far everywhere else in the world people dyno them 10-15 hp under their ratings, but dyno's around Amsterdam produce figures that are 10-15hp higher then the toyota rating.
Got any 0-100km/h measurements? Should be around the 6secs mark with your gearing and hp.
10-15-2006, 11:16 AM
AE86 Dyno Results!
NoHachi, SR5, not GTS
Still I would expect an SR5 to be in the 70 to 90 WHP range...
10-15-2006, 04:12 PM
AE86 Dyno Results!
Thats what I meant..even my 1.2l 3K kitten gets better HP then that...come to think of it, so does my moms daihatsu cuore 0.8l.
10-15-2006, 08:49 PM
AE86 Dyno Results!
mine did 51rwhp Smile
10-16-2006, 06:28 AM
AE86 Dyno Results!
Mux213 Wrote:NoHachi, SR5, not GTS
The 84-87 Corolla SR5 came with a 72HP@Crank engine. At the rear wheels brand new it should put down 50-60rwhp. My Corolla has had a recent tune up with all new toyota parts from the dealership and compression is 10psi under stock all cylinders. My buddy dynoed his 1.3L starlet and he had 42whp. heres a pic of the dyno sheet.
10-16-2006, 09:13 AM
AE86 Dyno Results!
Wraith,
My bad.. I thought the SR5 came closer to the GTS then that... My GTS did 112 whp on the Dyno earlier this year so thats alot of difference....
Still looks like your well within factory specs then so thats great!
  Tuned 4AGE results irishtwincam 52 107,353 07-19-2013 10:30 PM
Last Post: makkuro
  Silvertop burning oil - compression results Jezza_hr 3 5,664 10-18-2008 02:51 AM
Last Post: jondee86
  Ignition advance, Dyno and Detonation apardal 10 17,841 04-21-2008 11:02 AM
Last Post: KrizKH
  Dyno proven header for AE86 ????? jondee86 10 16,377 03-27-2008 05:15 PM
  Wierd Dyno result Knudsen 25 25,019 05-05-2005 06:16 PM
Last Post: Knudsen
