brakes
03-29-2005, 12:57 PM
brakes
What brakes does a ae86 have in the front? How big are the disks? ANd howbig is the piston?
Broken down 1984 Trueno HB ![]() |
03-29-2005, 01:08 PM
brakes
234mm disks, 19-20 mm thick, vented (except Australian ones), 51mm brake cilinder, 1 pot, 140 mm between holes for brake caliper mounting.
03-29-2005, 01:30 PM
brakes
WHat diameter does the piston have?
03-29-2005, 01:32 PM
brakes
Quote:51mm brake cilinder |
03-29-2005, 01:38 PM
brakes
Sorry. Thought you mean the master cilinder. Thx for the info.
03-29-2005, 01:43 PM
brakes
You're welcome !
PS: the master cilinder should be 3/4". But I don't actualy measure that (I will replace mine with AE82 1" one - measured). |
Rear brakes | totta Crolla | 0 | 1,069 |
02-03-2023 12:54 PM Last Post: totta Crolla |
Switching diffs for disc brakes? | trippin | 6 | 3,133 |
07-08-2022 03:35 AM Last Post: trippin |
Rebuild rear disc brakes toyota crown ms112 axle | bozu | 0 | 3,927 |
Hydraulic handbrake with stock rear brakes | Dino86 | 11 | 16,177 |
07-11-2014 08:33 PM Last Post: Dino86 |
S13 Front brakes in AE86 rear | heshan | 25 | 29,547 |
02-01-2014 12:37 PM Last Post: heshan |
