U-joint on drive shaft - Beams 6s box
08-17-2011, 10:09 AM
Hi Guys,
Looking for a universal joint which can fit for the Beams 6s box and the 86 drive shaft, I will weld the joint to the 86 drive shaft and do the balance. Any idea for the parts number, cant find it here in HK in the local junk yard. Or any suggestion / example for the drive shaft which fit the 6s and a normal Zenki diff. THanks, |
08-17-2011, 11:15 AM
any tail shaft from RT132 corona to ra23 /40 /60 series celicas all having 18 r motors use the same size altezza and 18rg are the same spline
08-18-2011, 03:59 AM
THanks Glenn,
THere you are. |
Clicking noise from glove box | chrisae86 | 4 | 1,948 |
09-08-2022 11:36 PM Last Post: chrisae86 |
Play between steering column and intermediate shaft after manual rack sonversion | DaLanZhu | 5 | 6,764 |
Steering shaft issue | Ryo | 15 | 12,714 |
11-19-2018 09:52 AM Last Post: Ivan141 |
Final drive calculation. | Aram | 31 | 31,982 |
12-24-2014 03:08 PM Last Post: Uzelac |
Propeller shaft universal joint | kawo | 1 | 4,271 |
05-19-2014 11:05 AM Last Post: Uzelac |
