URGENT QUESTION
01-23-2008, 05:19 PM
URGENT QUESTION
How do i install the camber plates? I have the aeu86 camber plates, but i dont know in which order i have to put in the parts, i have a spacer, the other thingy and the camber plate? Can anyone help me pls?
No Smorking AE86 |
01-23-2008, 05:37 PM
URGENT QUESTION
01-23-2008, 05:43 PM
URGENT QUESTION
I know what they look like , the thing is the part that should bolt on to the shock has the wrong (schroefdraad) no idea how to say it in english. The bolt part doesn't fit on the top of the koni shock
No Smorking AE86 |
01-23-2008, 05:57 PM
URGENT QUESTION
I see... I'll have to see about that tonight...
Do you have short or long stroke konis? 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
01-23-2008, 05:58 PM
URGENT QUESTION
Zal het ook ff int nederlands zetten. Kan het dat het stukje met de schroefdraad wat bij de camber plates komt niet past op koni schokdempers. ze hadden nochthans gezegd van wel.
No Smorking AE86 |
01-23-2008, 05:59 PM
URGENT QUESTION
normal longstroke ae86 yellow konis
No Smorking AE86 |
01-23-2008, 06:16 PM
URGENT QUESTION
Do you have Tein Camberplates? then you got a same problem as me I hope banpei can help us when he got home tonight
01-23-2008, 06:43 PM
URGENT QUESTION
koni's use other threads.
Just use the nuts you got with the koni's and your good to go, it worked fine for me, drove a lot with it like this way and everything was fine "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
01-23-2008, 06:57 PM
URGENT QUESTION
The Doctor Wrote:koni's use other threads. Do i have to use something from the old camber plates, as the old ones turn freely on the top and the new ones hit the part that holds the spring. And if i put the spacer on first, then there is no room left for the nut on top. I'm confused No Smorking AE86 |
01-23-2008, 07:07 PM
URGENT QUESTION
i just used the stock spring cap and then the camberplate, but i got Cusco camberplates, dunno 'bout the AEU86 plates.
The stock topmount has indeed a bearing in it, the camberplates can turn freely enough too, because of the pivot in the plate. "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
Urgent replies needed DIFF OIL + refresh | Okami | 6 | 6,497 |
06-17-2012 09:56 PM Last Post: Okami |
Need urgent help strut mounts. | ditn | 5 | 7,655 |
01-21-2012 03:37 PM Last Post: ditn |
URGENT: Need electric help, injectors not fireing | ZaX | 13 | 16,044 |
07-05-2011 01:10 PM Last Post: Nomuken |
Urgent Levin hood question... measurements and weight | Okami | 8 | 14,144 |
03-15-2011 11:36 PM Last Post: Gtsi-R |
Urgent. AE86 Door hinge bolt numbers. Need help | hachirokuGTV | 2 | 5,225 |
09-19-2010 08:16 PM Last Post: hachirokuGTV |
