URGENT QUESTION
01-23-2008, 05:19 PM
URGENT QUESTION
How do i install the camber plates? I have the aeu86 camber plates, but i dont know in which order i have to put in the parts, i have a spacer, the other thingy and the camber plate? Can anyone help me pls?
No Smorking AE86
01-23-2008, 05:37 PM
URGENT QUESTION
[Image: AEU86 AE86 - URGENT QUESTION]
01-23-2008, 05:43 PM
URGENT QUESTION
I know what they look like Tongue , the thing is the part that should bolt on to the shock has the wrong (schroefdraad) no idea how to say it in english. The bolt part doesn't fit on the top of the koni shock
No Smorking AE86
01-23-2008, 05:57 PM
URGENT QUESTION
I see... I'll have to see about that tonight... Undecided
Do you have short or long stroke konis? Dumb question
01-23-2008, 05:58 PM
URGENT QUESTION
Zal het ook ff int nederlands zetten. Kan het dat het stukje met de schroefdraad wat bij de camber plates komt niet past op koni schokdempers. ze hadden nochthans gezegd van wel.
No Smorking AE86
01-23-2008, 05:59 PM
URGENT QUESTION
normal longstroke ae86 yellow konis
No Smorking AE86
01-23-2008, 06:16 PM
URGENT QUESTION
Do you have Tein Camberplates? then you got a same problem as me Tongue I hope banpei can help us when he got home tonight Thumbs up!
01-23-2008, 06:43 PM
URGENT QUESTION
koni's use other threads.
Just use the nuts you got with the koni's and your good to go, it worked fine for me, drove a lot with it like this way and everything was fine Smile
01-23-2008, 06:57 PM
URGENT QUESTION
The Doctor Wrote:koni's use other threads.
Do i have to use something from the old camber plates, as the old ones turn freely on the top and the new ones hit the part that holds the spring. And if i put the spacer on first, then there is no room left for the nut on top. I'm confused Confused
No Smorking AE86
01-23-2008, 07:07 PM
URGENT QUESTION
i just used the stock spring cap and then the camberplate, but i got Cusco camberplates, dunno 'bout the AEU86 plates.
The stock topmount has indeed a bearing in it, the camberplates can turn freely enough too, because of the pivot in the plate.
  Urgent replies needed DIFF OIL + refresh Okami 6 6,497 06-17-2012 09:56 PM
Last Post: Okami
  Need urgent help strut mounts. ditn 5 7,656 01-21-2012 03:37 PM
Last Post: ditn
  URGENT: Need electric help, injectors not fireing ZaX 13 16,044 07-05-2011 01:10 PM
Last Post: Nomuken
  Urgent Levin hood question... measurements and weight Okami 8 14,150 03-15-2011 11:36 PM
Last Post: Gtsi-R
  Urgent. AE86 Door hinge bolt numbers. Need help hachirokuGTV 2 5,226 09-19-2010 08:16 PM
Last Post: hachirokuGTV
