Use LocTite on Bolts ?????
05-22-2010, 05:19 PM
Do you need to ever use LockTite (thread lock) on the car?
I used it on the inner tie rods - but do you need to use it on bolts, such as the two knuckle to strut bolts, or tie rod to knuckle, or steering rack to cross member bracket bolts, or control arm bolts??? I swapped in a manual rack and replaced bushings, ball joints, tie rods etc. I just torqued everything back together as it stated. I did not use any LockTite. |
05-22-2010, 05:30 PM
i have never used locktite on a car before.
Head bolts: You decide..... | oldeskewltoy | 8 | 10,211 |
11-11-2020 06:33 PM Last Post: oldeskewltoy |
ring gear bolts | DJexor | 3 | 5,518 |
12-26-2016 10:56 PM Last Post: totta Crolla |
torque setting head cylinder bolts | izanagi | 1 | 4,959 |
05-29-2015 01:23 AM Last Post: oldeskewltoy |
Which threadsize to use for the vdo oil temp sensor? | ditn | 8 | 11,347 |
03-15-2012 01:56 AM Last Post: Project D |
why do you use "roll center ajuster"? | leckter | 15 | 18,435 |
02-07-2012 07:04 PM Last Post: Bean |
