Using a Resistor pack for a non-Resistor MAP injector setup?
08-10-2007, 08:46 AM
Guys, as we all know, the MAP sensored 4ag came without resistor pack. The ECU limits the amount of current flowing through the injector using a injector driving transistor. On US cars (AFM equipped), current is regulated by using an external solenoid resistor to limit current through the injectors. So what if I used a resistor pack for my map sensor setup? What would this cause?
Some logic reasoning:
Resistor pack (2.5 ohms) + Injector (2.5 ohms) = total 5 ohms.
Using Ohms Law, the (V=IR), the current flow is about 2.5 amps using a nominal voltage of about 12.5 Volts.
If I omit the resistor, total current flow through the injectors is about 5 amps.
If the current is controlled by the ECU, with me adding a resistor pack will this cause an always lean condition because of the added resistance? Or will the ECU know and compensate? Reason I'm asking is that I just converted to MAP using a US Harness. I kept the provision for the resistor pack (really the person that did the conversion). I'm using ~ 2.5-3 ohm 182 cc injectors to try to match the original map setup rate. I have no clue if the car is running rich or lean just that my check engine light flashes.
Messages In This Thread
Using a Resistor pack for a non-Resistor MAP injector setup? - style86 - 08-10-2007 08:46 AM
[] - jamiemirror - 08-10-2007, 09:33 AM
[] - style86 - 08-12-2007, 06:02 AM
  4AGE Injectors resistor Blaze0010 4 394 01-27-2025 03:20 PM
  AFM to Map Conversion ps13michi 3 3,304 01-06-2022 10:34 AM
Last Post: ps13michi
  Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP mister86 12 11,333 02-10-2020 06:39 PM
Last Post: Power_uP
  What suspension set up are people using? kazi 8 8,331 07-06-2017 05:26 AM
Last Post: headrush
  extracted freedom ecu 16v ignition map ditn 7 9,010 08-22-2016 10:01 AM
Last Post: ditn
